Pulleys!!!
  • Thread starter Thread starter cas69aus19
  • Start date Start date Oct 11, 2005
cas69aus19
50
B-town NV
Oct 11, 2005
  • Oct 11, 2005
Just got my engine back and everything went smooth until i had to put the pulleys on. Thats when i noticed that when they rebuilt it they put a new balancer on and switched from my 3 bolt balancer to a 4 bolt balancer. I spent 2 1/2 days looking for pulleys. I finally found a pair that fit, but i am worried about cavatation on the water pump pulley because it is significantly smaller than stock. Does anyone know where i can get a crank pulley(pulley set) that will get the water pump pulley back to the proper size?
J
jmenke
211
Melbourne, FL
Oct 12, 2005
  • Oct 12, 2005
you might want to confirm that the balancer they installed is correct for your engine.
The newer 4 bolt versions are typically 50 ounce (offset) balance, whereas the older 3 bolt units were 28 ounce (offset).
G
grego37
576
Fresno CA
Oct 12, 2005
  • Oct 12, 2005
on a street car, you are better off overdriving your waterpump some, especially if you live in a hot climate.
my crank pulley is 6.5" and my waterpump pulley is 5.5"
But say if you have a circle track car buzzing at 4000rpm+ all day, you'd want to underdrive your waterpump.
What is the difference on your two pulleys?
whats your car being used for?
what car do you have?
contact jack wilson (tech guy) at Stewart Components, he'll steer you in the right direction on pulley ratios, and cooling tech.
A67StangMaster
401
San Jose CA
Oct 12, 2005
  • Oct 12, 2005
HOw do you put a balencer back on, could i do it at home or I have to take it to a shop
Idler pulley as substitute for Power Steering Pump ?
  • Bhenders
  • Jul 15, 2026
  • Other Auto Tech
Other Auto Tech Jul 16, 2026
LILCBRA
H
1966 mustang starter and pulley troubles
  • Hotrods4ray
  • Sep 24, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 10, 2026
Realmongo
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Oct 22, 2026
DadLife0724
