PULLING MOTOR - 1 Question
  • Thread starter Thread starter Paul Perreca
  • Start date Start date Aug 27, 2005
1 of 2 Next Last
Paul Perreca
1,085
  • Aug 27, 2005
I am going to be pulling the motor out next weekend, Everything is unhooked as of now (exception of trans) -
QUESTION!!!!!!
How is the best way to get the engine out, can i Leave the trans in the car?? Take out the trans first, than the engine, OR take the Engine out w/ the trans together???? I'd like to be able to leave the trans in, but I will do whats easiest --
THANKS
on the road to more pony's under the hood of my pony
txstang84
1,639
42
69
Tuscola, tx
Aug 27, 2005
  • Aug 27, 2005
highly debated subject here....
this is only my personal preference, but with a manual car, i usually pull the tranny from underneath, then pull the motor with bellhousing attached...
then again, if you've got an tilt leveler, go ahead and pull them as a unit...if you don't have one, there's a higher potential to popping the windshield with the tranny. Either way you're going to spill some tranny fluid on the ground-even if you drain it completely
RYC CUKR
1,437
Orlando
Aug 27, 2005
  • Aug 27, 2005
Personally I would pull them both at once. I have done it both ways and let me tell you it is one pain in the ass to trie to line everything back up again if you leave the trans in the car.
vristang
4,933
101
124
Seattle
Aug 27, 2005
  • Aug 27, 2005
If I had a trans jack set up I would try removing the trans from under the car. It is pretty easy to pull them both at the same time though, especially with the leveler mentioned by txstang84.
I have never really considered pulling the trans before the motor. Fighting the exhaust into place is bad enough, I don't want to have to fight the trans as well.
txstang84
1,639
42
69
Tuscola, tx
Aug 27, 2005
  • Aug 27, 2005
guess i've just been lucky in the past...i never really had any issues stabbing the tranny from under the car, provided that i had it up on stands...
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Aug 27, 2005
  • Aug 27, 2005
I've done it both way.
I pulled an engine and t-5 once. We were stripping the car so we hacked off the exhaust and that made it easier.
When i pulled the engine from an AOD car, we unbolted the trans. Honestly, it wasn't all that much harder.
Lining it back wasn't that big of a deal either. Just make sure you have at least 3 guys there.
V
v8only
2,378
22
49
Aug 27, 2005
  • Aug 27, 2005
Honestly, being on your back while wiggling that trans in sucks. you've got to yank the exhaust anyhow, just lose the driveshaft and trans x member, and yank it all at once, it'll save you a lot of on your back time.
icarus
433
Frederick, MD
Aug 27, 2005
  • Aug 27, 2005
My votes goes to pull both at once. The four bolts that connect the trans to the motor is a PITA on your back. I hate pulling the trans. altough it's not a bad as pulling a trans on a sideways motor.
Paul Perreca
1,085
  • Aug 27, 2005
I have a lift that the car is on, and I have a trans jack specifically for my lift, it doesnt matter to me how I do it, I just wanna do it the "easier" way, if there is one.... I can take the tran off the bellhousing, and pull the motor and bell together, that would be simple,
Maybe to pull it, i should take them apart (engine and trans, trans out first, than pull motor), but put them together and put the engine and trans in together at the same time.... maybe.... ??
Paul Perreca
Thanks!
V
v8only
2,378
22
49
Aug 27, 2005
#10
  • Aug 27, 2005
  • #10
it's easiest to "pull" them together, but it can be a pain in the butt to drop them in together (unless you get a leveler) as you have to balance them going in. IF you have a lift, yank them as once piece, then drop in the engine seperately, bolt in the trans after.
bobbys9350
472
#11
  • Aug 27, 2005
  • #11
Just Pull The Motor Seperately
mustangGT85
264
Orange CA
Aug 28, 2005
#12
  • Aug 28, 2005
  • #12
pull them as a unit. not hard. trust me.
~Steve
Paul Perreca
1,085
#13
  • Aug 28, 2005
  • #13
steve, why did you pull your motor, just curious, and thanks for the pics..
Paul Perreca
Paul Perreca
1,085
#14
  • Aug 28, 2005
  • #14
Does the shifter come off with 4 bolts, and thats it and than the tranny can come out, or is it more complicated than that??
BERT306
75
#15
  • Aug 28, 2005
  • #15
I pulled the motor and C-6 together (YES C-6, that thing is a hoss!)
I didn't have a leveler either! just hooked my picker up towards the front of my motor and had a buddy sittin on the cowl to hold down the tailshaft of the tranny while i pulled it out....first thing i did was threw that C-6 off a bridge!!
Paul Perreca
1,085
#16
  • Aug 28, 2005
  • #16
y is the c 6 so bad, and again, how does the shifter come off?
331 stang91
261
wisconsin
Aug 28, 2005
#17
  • Aug 28, 2005
  • #17
I pulled just the motor and left the trans in. I had no problems getting it back in. Took maybe 5 min to get it to line up.Good luck let us know how it goes.
U
universalstang
#18
  • Aug 28, 2005
  • #18
Paul,
my 2 cents is pull engine seperatly. I also installed a C6 in my 88 notch, and the 1st torque converter didnt seat properly in the 347 crank. So i had to pull it out completely again by myself. I used a regular 2 ton jack that has the big wheels on one end and it was fairly easy. I only weigh around 200, but i'm skinny!!!
If its a automatic when reinstalling, make sure the torque converter is locked in the tranny. You'll spin it and should hear it engage 3 times while moving back on the tranny shaft. Then make sure the flywheel and converter are pointing in the same direction, so when you have tranny and engine starting to mate they are in perfect position.
Also if you change the torque converter, make sure it fits in the input on the rear of the crank. My didn't because it was for a 351, and it was 1" to long so out the tranny came. Had to do it again.
mustangGT85
264
Orange CA
Aug 29, 2005
#19
  • Aug 29, 2005
  • #19
Paul Perreca
because it went into my Rx-7. muhahaha!
~Steve
vristang
4,933
101
124
Seattle
Aug 29, 2005
#20
  • Aug 29, 2005
  • #20
It really is as easy as 4 bolts.
Sometimes it is tough to reach them though. Also if silicone was used to seal the shifter plate down it can be tough to break the seal.
So, I guess there can be more to it.
1 of 2 Next Last
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
