pulling rear axles?
  • Thread starter Thread starter golf4283
  • Start date Start date Jun 15, 2006
golf4283
1,253
Orland Park, Illinois
Jun 15, 2006
  • Jun 15, 2006
Ok i just bought an 8 inch that came from a 1970 fastback. I got it home and took the drum covers off and took the bolts out and both of the axles will not ocme out at all (obviously i took out the 4 retaining nuts on each axle). What am I missing? I fear that this rear end may be useless and I was just getting excited about almost being ready to drive again. Ugh.
Platonic Solid
1,960
CT-USA
Jun 15, 2006
  • Jun 15, 2006
That's common. The easiest way is to use a slide hammer.
krash kendall
1,258
Aldergrove, B.C. Canada
Jun 15, 2006
  • Jun 15, 2006
If you don't have a slide hammer, put the drum on backwards with the wheel nuts on a few threads and use the drum as a slide hammer.
golf4283
1,253
Jun 15, 2006
  • Jun 15, 2006
ok one of the axles came off with the backwards drum but the other one is just a PITA. Any other suggestions that I can use?
MrBobMarley
460
Ft Myers, FL
Jun 15, 2006
  • Jun 15, 2006
You could try beating the backwards drum with a deadblow hammer somewhat lightly. I'd use a 2x4 to buffer the drum. Just trhowing out ideas.
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Jun 16, 2006
  • Jun 16, 2006
The slide hammer axle puller may be needed. Do you have an Autozone or and Advanced Auto nearby? They usually have a free tool lending program.
Platonic Solid
1,960
CT-USA
Jun 16, 2006
  • Jun 16, 2006
Or go all out and spend $8 at your local rental place.
I suppose if you want to turn this into a major project, you could try heating the outside of the casting near the bearing with a propane torch.
golf4283
1,253
Jun 16, 2006
  • Jun 16, 2006
thats a little too much for me but thanks for the idea. Ill have to try the slide hammer. I hope it works cause that stupid thing is in there good
C
C6AE
145
Ma.
Jun 16, 2006
  • Jun 16, 2006
I have a slide hammer, works every time.
I've taken a few axles out that definately would not have come out with a drum on backward.
Another method I have heard of, but never tried, is using a chain attached to the axle bolts. The weight of the chain is supposed to pull it out when you yank on it.
Can't help but laugh at what I just wrote though...
yeloxr7
429
#10
  • Jun 16, 2006
  • #10
I have a really big (3/4" shaft) slide hammer with an adapter that bolts to the axle flange and screws onto the slide hammer shaft. It has worked every time. It also has a couple of tools that can be used to pull axle seals out as well. We got it from Sears many years ago. The axle flange adapter can be used as a wheel hub remover for FWD cars as well....
jes72mustang
224
S. Central PA
Jun 16, 2006
#11
  • Jun 16, 2006
  • #11
I went through the samr thing a couple of months ago. I was able to pull one axle out fairly easily but could not get the other to budge. I fought with it for several hours. Then I went and rented a slide hammer ($8 for the day) and had that stubborn axle out in two good pulls. took more time running to the rental place and back then it did to get the axle out. I wished I would have done that in the first place and saved half the day.
Any job can be easy with the correct tool.
mfp4073
387
Hells Ditch, FL
Jun 16, 2006
#12
  • Jun 16, 2006
  • #12
hehe, I have used either the backward drum method or run a chain to the axle nuts and used the drums as hammers on the chain.....slide hammer prolly works better....
golf4283
1,253
Jun 16, 2006
#13
  • Jun 16, 2006
  • #13
slide hammer was a success!. That dang thing was stuck in there tight. Im definaately going to have to take the housing and axles in to have new bearings put on.
dennis112
1,561
36
79
Jun 17, 2006
#14
  • Jun 17, 2006
  • #14
Thanks for the feedback, glad it worked!
Which SN95 axles for 93 LX, disc brakes, ABS rings?
  • dan50
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 3, 2026
7-UP BILL
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
