pulling to the right
dynobyke
hey guys i have a 1989 5.0 and havent had any problems with it until i installed subframe connectors, lower control arms, torquebox reinforcements. now the car completely jerks itself out of the lane (to the right) when i punch the gas, i can counter this by pulling the steering wheel to the left but as soon as i let off the gas and the car settles back down, it pulls slightly back to the left and i have to recompensate with the steering wheel again, this only happens dramatically if i go full throttle, but it happens anywhere in the entire speed band, i also just replaced the drivers side tie-rod because my driver's side tire is getting wear on the outer tread. it still is being worn down even after replacing the tie rod. can anyone help me figure out what the prblem may be? i dont want to have to keep replacing tie rods if the problem is elsewhere. does the front end need more support now after the lower control arm and subframe install, or has something more serious already been damaged? it feels more like the body of the car is loose and twists and the wheels follow, instead of the steering itself pulling the car. i was thinking of just throwing on a strut tower brace to even the car out, but want to take care of this problem first for sure instead of just experimenting with parts and hoping it works. thanks for any advice or experience you guys have with this issue. also the car is a convertible
yes it was aligned and the front were rotated, because i noticed my passenger side tire was worn down, and i didnt know why, then i rememebred they rotated them. but then the next few days i noticed my driver's side becoming worn down again. also when they replaced the tie rod i did notice a difference in the individual wheel not being loose anymore and wobbling, but still the entire body of the car twisted to the right. i have heard that control arms can cause the rear end to lift up and i thought maybe that is what causes it but i didnt expect it to be this severe, i dont think anything has broken or needs replacement it just feels like something else needs to be supported to make up for the rear end stiffness now or am i off base?? i have been driving it like this for a while now but everytime i have a friend in the car and i punch it, they say my car fishtails and its not really fish tailing, its just the rear end pulling to the left and my front pulling to the right. traction has improved with the install though
yes there is a chance that happened, the subframes were not welded on and i didnt supervise the installation., theyre not full-length either they are the short bbk subframes. i also suspected that because the car doesnt seem to sit level anymore but i couldnt be sure. should i just get full-lengths welded on and supervise it next time, or have them readjust the ones i have? or has the damage to the chassis already been done? thanks for fast replys. would the subframe issue be causing my drivers side tire to wear on the outer tread because of the way the chassis is sitting or is that a different issue
If you don't have weld in subframes and they are bolted in you could remove them yourself and run the car to see if it is still happening. That way you could eliminate the sub frames as the possible cause.
i change my own oil,sparkplugs, etc. nothing very technical. if its sitting unevenly after the install does that mean they installed them while it was on a fork lift instead of the drive-on lift? i have 4 jack stands and i could get the car up and unbolt them, should i set the jacks under the axles so the suspension is loaded while they are going on? im just confused because i dont know how they could have put them on if they didnt use the drive-on lift, doesnt the fork lift prongs go directly where the subframes go? i just dont want to redo the same job, ill take them off tomorrow though and see how it rides. i tried to install them initially myself but they were tough to get on, and i had the arms and torquebox stuff to go on too so i just had them do it all together. i'm sure the car is going to require another alignment even after theyre uninstalled anyway so i may as well have them do it all again. maybe they can take them off or fix it for no charge if in fact they did screw it up but i cant prove it
yes must have been axles. It shouldn't be that hard to remove them and if it is not the problem to reinstall them. I believe if they are like mine that they are just 2 bolts front and back. So a total of 8 bolts for both sides.
im going to work on it first thing tomorrow and ill post an update if i am successful, but i will have to play around with the jack for a while to find the right spot so there is no pressure on those bolts because if they did put them on wrong and the weight of the car is on them i doubt the bolts are going to come out at all, they might even be bent to hell or widened the bolt holes who knows, i will find out tomorrow. thanks for the help, appreciate it
