Purchasing 1st Fox, need advice
  • Thread starter Thread starter Blown02svt
  • Start date Start date May 30, 2025
First Prev 2 of 2
gkomo
now i can hopefully expect to receive the shaft
Aug 2, 2024
2,345
1,562
133
San Diego, CA
May 30, 2025
#21
  • May 30, 2025
  • #21
Are you dead set on this one? Cause for $17k that should open you up to a lot of other good clean foxes.
Reactions: slow84lx and 91AOD5.0LX
Admin Dude
Jan 4, 1985
43,580
21,743
234
Box behind Walmart
May 30, 2025
#22
  • May 30, 2025
  • #22
I can't see a fire wall adjust so, it's probably running the stock clutch quadrant.
Admin Dude
Jan 4, 1985
43,580
21,743
234
Box behind Walmart
May 30, 2025
#23
  • May 30, 2025
  • #23
It gets $6-8K for what appears to be a pretty good paint job.
Interior looks good (standard saggy door card pockets).
Needs a shifter and I'd like to look underneath.
Post pics once you get it.
nicholase
I lubed and pushed, until it was all the way in
May 21, 2024
671
1,200
103
New York
May 31, 2025
#24
  • May 31, 2025
  • #24
For me the EFI delete would be a deal breaker. There's just no good reason to do that IMO. But I'm not you. So...
If the carb conversion doesn't bother you, then I suggest focusing on how it was accomplished. I'd make a mental list of all the things effected by deleting the EFI and see how each was accomplished. The wiring is what would worry me the most. Future wiring gremlins can be horrible especially if you dont know how it was done or what wires are what.
A few examples...
I'd want to see some pictures of how he did the body wiring as the engine harness and the body harness merge together.
That's an air bag car. Is that deleted too? Does the air bag light come on and go off when the key is turned to run? Do the factory guages work? Or were they bypassed?
What does the fuel system consist of? How is it wired? The factory in tank pump is run by the EEC and gets a signal from the PIP sensor in the distributor so it knows when the engine is being cranked or is running to turn the fuel pump on and off. That doesn't have a TFI style distributor. From the pictures it looks like an in-tank pump (or electric of some sort) dialed back to carb presure. What is controlling the pump? It's details like that that indicate quality work vs hack job. If it's an electric pump it needs to have a cutoff switch of some type. Either an oil pressure cutoff switch or electronic means are necessary for safety. Where is the fuel pump relay? That used to be controlled by the EEC. Is it in the factory location? Was it bypassed? It's these details that are difficult to sort out if you're not the one that did it.
Then little things like open valve cover breathers (smelly). I'd much rather have a functioning PCV setup. Is there a charcoal canister for fuel tank vapors? That's a system that would need to be modified when switching to carb. What was done there? Just a few little things you might not think about until your garage and clothes smell like gas fumes.
The cruise control seems deleted.
You're not just buying a car, your buying the previous owners work. So I'd make sure it seem well sorted. If it seems all half a$$ed I look for something better.
In any event good luck with your search! I must have looked at a dozen before I bought mine. I'm not trying to all over the car. Just mentiong things that would be very real concerns for me if I was looking at it.
My advise is to buy the best car you can. It's always cheaper in the long run. For $17 you can find some pretty nice lower mile all original cars that are a totally blank un molested canvas for whatever you want to do.
Reactions: slow84lx, 85GT4V, gkomo and 1 other person
Mustang5L5
Mod Dude
Feb 18, 2001
43,390
18,133
224
Massachusetts
May 31, 2025
#25
  • May 31, 2025
  • #25
At $17k I’d have to take a good hard look underneath at the body. Floors, strut towers, torque boxes, etc.
The carb thing would turn me off, but you are the one buying it.
I’d prob want to try and get it for $15k. If the paint and body are as good as it looks in the pics I’d be fine with $17k assuming the car checks off all your boxes. If it doesn’t, don’t settle.
Reactions: 91AOD5.0LX and 85GT4V
Rdub6
So while I wait to figure out my rear end issues
5 Year Member
Dec 29, 2017
3,977
2,960
153
Long Island, NY
May 31, 2025
#26
  • May 31, 2025
  • #26
I’m late to the party, but……. Offer him $13…… he’ll take $15…… if you really want it. Looks pretty good to me!
That engine bay does look nice and kind of brings back the nostalgia of the 60’s / 70’s muscle cars, which is pretty cool!
Reactions: limp
Admin Dude
Jan 4, 1985
43,580
21,743
234
Box behind Walmart
May 31, 2025
#27
  • May 31, 2025
  • #27
I [still] know a few old-head dudes that would take one look at a Fox EFI and say, "Nope" and pull it off if they were going to keep the car.
I prefer the FI setups (even ours). You look at a carb engine and say, "WTF is it meow???" and you get no response
nickyb
I gotta say i never painted my nuts, Never Ever
3,074
1,686
163
nevada
May 31, 2025
#28
  • May 31, 2025
  • #28
Your in Kansas so I'm guessing no a/c is o.k. , here in Nevada were its been 100 degrees this week and that's the tip of the melting ice burg, we don't do no a/c cars. If you can tune a carb and don't have to pass a smog test then that fox is just what you should buy.
E
Ethereal_Zer0
36
12
18
May 31, 2025
#29
  • May 31, 2025
  • #29
If you can, see if you can get receipts/paperwork for every non-OEM part and verify they are installed on the car. That will give you a general idea of what is on the car and how long each part has been on the car. Also if you need to replace stuff in the future you'll again know what is standard vs non-standard so you aren't accidentally buying the wrong parts. I'm thinking specifically of stuff like that brake booster which may not be from a fox car.
Reactions: 85GT4V
2000xp8
SN Certified Technician
Aug 8, 2003
8,078
1,659
194
NJ
May 31, 2025
#30
  • May 31, 2025
  • #30
Keep this in mind, 90% of people looking for a fox will probably pass because the carb swap. So if you want or have to sell it, you have shrunk your buyer pool significantly.
Would I buy a nice car with a swap? Maybe, but if it takes 2-3 grand to put the efi and ac back in, I'm hitting them for 6 grand off the price. Labor, even if it's mine isn't free.
Reactions: General karthief
Rdub6
5 Year Member
Dec 29, 2017
3,977
2,960
153
Long Island, NY
May 31, 2025
#31
  • May 31, 2025
  • #31
It goes like this when you buy a used car like a Fox.
Buy it because you think it’s the right thing
You dig in, drive it a bit, and you find all the little things that need fixing that you didn’t see before and you have a little buyers remorse.
You start fixing things, improving things, making it your own, until you love it. Now it’s “yours”.
Then you get so attached and never want to sell it.
Reactions: Ethereal_Zer0, 85GT4V and 91AOD5.0LX
limp
wrap a little cheese around it and its a done
5 Year Member
Oct 4, 2020
5,520
2,947
173
Florida
Jun 1, 2025
#32
  • Jun 1, 2025
  • #32
So your first post was a bit misleading... I too expected some half a$$ed car... If this isn't a lipsticked pig, its a stunning car based on the pics shown here..
As nicely done as this car is I would not even think of converting back to FI.......
Being relatively new to fox bodies, do the computers in these later model foxes do more than just engine management?? If so then how have these functions been made to work properly???
As already said check the frame rails and front towers for rust...
What are your plans for this car?? Driver, Cars n coffee car, Racing?? To me that would be a big contributor to getting the AC working again or not... or at least being in a hurry or not...
Bullitt347
I have been doing it wrong this whole time
4,068
3,141
204
Middle of Maine
Jun 1, 2025
#33
  • Jun 1, 2025
  • #33
85GT4V said:
I’m with @gkomo , looks pretty good in the pics! A couple choices I wouldn’t have made (i.e. hood pins) but, it’s a good looking car that, if priced right, would be a great place to start from.
Hood pins ... because Fiberglass Hood.
The hood pins are actually a good idea in this instance.
Reactions: Ethereal_Zer0, 85GT4V, limp and 1 other person
General karthief
Mod Dude
Aug 25, 2016
28,140
10,761
213
polk county florida
Jun 1, 2025
#34
  • Jun 1, 2025
  • #34
If you do a 'hands on' look at the car I'd take a small flashlight and look under the dash, that is where the 'hackery' can be hidden.
follow the underhood wiring and inspect as much as you can.
it looks good and may be a good cruiser but?????
For me a carb swap on a EFI car is a no-go.
Reactions: limp and nicholase
Admin Dude
Jan 4, 1985
43,580
21,743
234
Box behind Walmart
Jun 1, 2025
#35
  • Jun 1, 2025
  • #35
And look at the frame rails where the k-member bolts up.
Reactions: General karthief and limp
2000xp8
Aug 8, 2003
8,078
1,659
194
NJ
Jun 1, 2025
#36
  • Jun 1, 2025
  • #36
To me, hood pins signify that they purchased the wrong brand hood. The good ones for a street car still support the safety latch. I'm sure they cost a lot more, but i'd probably pay any dollar amount not to have hood pins.
At this point a factory EFI harness setup is probably too much effort so i think someone needs to plan for a terminator X. The computer isn't needed for anything other than the engine.
I do think it's a nice car and while surely no fox is perfect it needs expensive work just to get the basics back on the car.
Let's say there were different kinds of issues, like the rear didn't function correctly, you could get some discs, rebuild the rear and feel good about it.
Or maybe the trans grinded, you could do a new clutch and a TKX.
It's just not the same as putting things back on the car that should have never been removed in the first place.
The carb swap is a telltale sign someone that owned that car has no clue what they were doing.
Reactions: nicholase
Blown02svt
14
Kansas
Jun 1, 2025
#37
  • Jun 1, 2025
  • #37
Soooo…I looked at it in more detail this morning. This car is NOT slightly modified…. It has a 347 stroker, aluminum heads, Siebert Performance carb, cammed, 9” rear end, battery has been relocated to the rear hatch, MSD ignition, drive shaft loop, subframe connectors, different fuel take with the pickup ports in the back at the bottom of the tank, new fuel lines up to a regulator under the hood, list goes on…obviously set up for racing. However, looking underneath, I wasn’t able to find any rust, everything looked pretty straight, shock towers were fine, doors were aligned and shut without effort, no signs of stress on the A-pillars, paint was in excellent conditions (probably 8 out of 10 if not better), interior was also in great shape (8/10 here too). I took it for a spin and it drove pretty well, tracked straight down the road, idled very well, very street able car for sure. Not all of the gauges worked, temp and oil pressure didn’t function but those two gauges were in the gauge pods on the dash. Temp stayed right under 200 and oil pressure was good. I didn’t hammer on it but it pulled pretty good just cycling through the gears. I know that there is a little room in the $17k…
And I should add…I’m not looking to put it completely back to stock, use it as a daily driver or race it. More looking for something that I can drive around town, go to a car show, occasionally drive it to work and most importantly have fun with my sons in it…
Reactions: limp, 85GT4V, Ethereal_Zer0 and 1 other person
Willybill32
But at least it's tight!
5 Year Member
Jul 16, 2019
643
368
83
Lexington, KY
Jun 7, 2025
#38
  • Jun 7, 2025
  • #38
It’s a beautiful car from the pictures you provided. I’m like some other commenters in that a carburetor conversion to an EFI car is a turn-off, but that’s only my take. What I would be very interested in looking at is how the person doing the conversion handled modifications/eliminations of the stock EFI wiring. I read so many stories about guys picking up a used and “modified” Foxbody and have many headaches because the guy doing the work just made a mess out of the wiring. In your case, that doesn’t look to be the case, but I’d still make sure I knew what was in store…
Bill
Reactions: limp and 85GT4V
manicmechanic007
5 Year Member
Sep 26, 2017
2,567
727
143
Roy, Utah
Jun 21, 2025
#39
  • Jun 21, 2025
  • #39
I would pass
Find one that is mostly ALL stock
First Prev 2 of 2
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Take a look at my rack!
  • bicknell
  • Sep 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2025
Willybill32
G
Gen3 Coyote Motor Swap into 2014 GT
  • GTman14
  • Apr 2, 2025
2005 - 2014 S-197 Mustang -General/Talk- Apr 4, 2025
