Purpose of painting an Engine Block?
MeanGreen
1,160
I've seen some recent pics of motor build ups some of you all did and painted the block? Is there a reason for this or just like a colored block? Does it help with protection and wear or something? Just curious as to why its done and the advantages of it. :shrug:
Simply put..if you take the time to rebuild you would usually want to take the extra effort to make it look cosmetically better...nothing looks worse than a block covered in surface rust...looks better and cleaner to work with. Also steel will aquire surface rust fairly quickly when uncoated and could cause contamination issues during reassembly.
Cool..... I plan on doing a new motor build. Waiting till after summer but thats all good to know. Thanks fellas:nice:
The only reason I wouldn't try powder coating the block at home is that I don't have an oven that large...
Otherwise, I would give it a try...
I don't see how powdercoating force heat retention, at least not any more than regular paint would.
jason
You can buy your own powder coating kit for a few hundred bucks.
Yeah, I have my own powdercoting setup, but I just don't have an oven big enough to powder coat my block. ;)
Powdercoating does sound cool....
Does it retain heat ?
They say that Powder coating does retain heat a little more than paint etc, but they make special high heat powders for blocks and headers which are not suppose to retain the heat as much.
jason
I can't remember what type of paint this guy used but he described it as black rough and krinkley looking.He could'nt figure out why he was over heating and after spending a bunch of money it was narrowed down to the paint on the block, so he stripped it and no more over heating.
