Push button engine start
Sorry It took me so long to answer your question.
I didn't install It so I really don't know how It's wired and all.
I found the owner's manual, the name Is
(COMMANDER model 7000+)
Four channel remote control security system and remote engine starter
code learning, code-morphing, new pulse-code valet.
Whatever the hell the rest of that stuff means you got me.
all I know, Is when he Installed It he needed the factory key, It's wired under the dash In this secondary Ignition,for the remote starter. Im sure they sell other systems like this, If you can't find this one. It cost me 300 bucks. you still need to use a key when you want to drive, I just put the key In the Ignition while Is running, turn It to the on position and step on the break, then you can put it in drive, If not It will just shut off. you can start It from at least a block a way
I don't know what would look ghetto about It? as for a step backwards?? all I know Is when It's cold as f*** outside I just start It for a few and jump In a warmed up car.
all you can see Is the transmitter, I guess that what you call It,.. on top of the windshield, you can't even see it from the outside and you really don't notice it Inside.
here are two pic's to see for yourself.
don't know If I helped you at all, but thats all I know about It.
H8
Thats a nice set up non the less. GTP was correct I was talking about a push button start switch. Thanks for the info anyway. As for my installation, it would look like it was a stock installation. I don't do crappy work. I just won a bid on e-bay for the switch, hopefully I will have time over the holidays to do the install and I will submit some pictures when I'm done.
