Push Rod Length
  • Thread starter Thread starter f8tlfiveo
  • Start date Start date Apr 24, 2015
f8tlfiveo
My wife likes my spool and blow-off valve.
Aug 8, 2007
1,585
102
64
Lancaster, PA
Apr 24, 2015
  • Apr 24, 2015
I am installing gt40 heads and roller rockers on my car. The stock pushrods @ 6.250 are not long enough. I used my pushrod length checker to try to figure out what length is needed. Should the rocker be able to move back and forth at all after torqued? There is pressure on the pushrod, it's not loose but you can push the rocker and it will spring back from lifter preload. At 6.300 there is no play whatsoever. Just wondering which way is right before I order longer ones.
Sent from my iPhone
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Apr 25, 2015
  • Apr 25, 2015
Read this....
Installation of Ford Racing (and other) Stud/Pedestal Mount Roller Rockers | Mustang Forums at StangNet
f8tlfiveo
Aug 8, 2007
1,585
102
64
Lancaster, PA
Apr 25, 2015
  • Apr 25, 2015
Says thread cannot be found
Sent from my iPhone
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Apr 25, 2015
  • Apr 25, 2015
Really? Works dandy for me. Are you downloading the link?
Try this
http://fordperformanceracingparts.com/download/instructionsheets/FordInstShtM-6564-All.pdf
f8tlfiveo
Aug 8, 2007
1,585
102
64
Lancaster, PA
Apr 25, 2015
  • Apr 25, 2015
I am using tapatalk on my phone, maybe that is why, second one worked, I'm going with the 6.300 pushrods and will shim if necessary
Sent from my iPhone
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Apr 25, 2015
  • Apr 25, 2015
You should be able to get away with the stock pushrods and those heads?
Does using the adjustment method in the above link give you a different result than you were seeing before?
f8tlfiveo
Aug 8, 2007
1,585
102
64
Lancaster, PA
Apr 25, 2015
  • Apr 25, 2015
Nope... With stock pushrods some of them are loose when torqued
Sent from my iPhone
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Apr 25, 2015
  • Apr 25, 2015
Sent from my iPhone
Even with no shims? How many miles are on your lifters (any chance of collapse)? You are certain that you're on the base circle of the camshaft when installing them, right?
It's very rare that stock pushrods are too short for GT40 heads. What's your head gasket thickness?
Depending on how loose they are, this might instead be a good excuse for you to mill the heads. It would probably cost you about the same as a new set of pushrods, but you'll have the satisfaction of knowing the deck surface is true and you'll add a little bit of compression in the process?
You could easily take .020 off of the head surface without running into issues.
f8tlfiveo
Aug 8, 2007
1,585
102
64
Lancaster, PA
Apr 26, 2015
  • Apr 26, 2015
The base circle of the cam would be any time the valves are closed correct?
No shims anywhere
The lifters were not collapsed when I had them out
Feel pro 9333 gaskets
Heads were just resurfaced and valve job done
Sent from my iPhone
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
Engine Pushrod Length?
  • foxbodyclark
  • Jan 25, 2025
Fox 5.0 Mustang Tech Jan 25, 2025
limp
M
Pushrod length
  • mattcrp1
  • Sep 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 4, 2025
mattcrp1
M
Engine Valve and or rocker noise .....new to this but dont mind getting my hands dirty.
  • mustang matt 1993
  • Jun 29, 2024
2K
Fox 5.0 Mustang Tech Jul 1, 2024
rednotch
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
