Engine Push Rod Lengths
  • Thread starter Thread starter mustang 88
  • Start date Start date Aug 15, 2013
M
mustang 88
60
cleveland ga
Aug 15, 2013
  • Aug 15, 2013
Just purchased afr 185cc aluminum heads ,will I need longer push rods.
15austin
27
SW Missouri
Aug 16, 2013
  • Aug 16, 2013
I have afr 185's #1422. Yes I had to get longer pushrods. I got 6.400 pushrods. Thats on a 5.0 block
Rick 91GT
Mustang Master
95
99
PA
Aug 16, 2013
  • Aug 16, 2013
Yes and depending what rocker you use that will also make is vary....only way to do it is measure.
If I can help let me know....
Sent from my XT907 using Tapatalk 2
Reactions: 84Ttop
f8tlfiveo
My wife likes my spool and blow-off valve.
Aug 8, 2007
1,585
102
64
Lancaster, PA
Aug 16, 2013
  • Aug 16, 2013
Measure twice, buy once
M
mustang 88
60
cleveland ga
Aug 20, 2013
  • Aug 20, 2013
Ri
I have scorpion 1.72 stud mount. I put them in tonight and the heads and it looks as if the roller is riding on the upper side of the valve stem do I need long or shorter push rods thanks for the help. From anyone
Rick 91GT
Mustang Master
95
99
PA
Aug 20, 2013
  • Aug 20, 2013
Longer
Reactions: mustang 88
M
mustang 88
60
cleveland ga
Aug 21, 2013
  • Aug 21, 2013
Well I'm ready to take my car to a shop for the first time in my life. Someone please tell me what my next step needs to be. I checked the rocker it is basiclly in the middle of the vavle stem. I set everything to zero lash then put 3/4 turn on poly lock,set it, and then barely snugged it. And it sounds like a clock. Is it possible that I still need longer push rods even though it is riding close to the middle of the stem. Here is my set up... Afr 185 renegades stud mount 1.72 scorpion roller rockers stock length push rods. PLEASE HELP I am at whits end. The lifters are only a couple of months old.
Rick 91GT
Mustang Master
95
99
PA
Aug 21, 2013
  • Aug 21, 2013
I'd go 1/2 turn personally... 3/4 usually is too much
M
mustang 88
60
cleveland ga
Aug 21, 2013
  • Aug 21, 2013
At 3/4 turn it still sound like a clock tough at a 1/2 turn wouldn't be even louder? I really don't know this is my first round with roller poly locks.
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Aug 21, 2013
#10
  • Aug 21, 2013
  • #10
dumb question. Did you set each valve when it is at TDC-? Did you adjust the valves in the correct timing order? You can't just start cranking them down arbitrarily.
M
mustang 88
60
cleveland ga
Aug 21, 2013
#11
  • Aug 21, 2013
  • #11
yes and my arm knows it I have set reset and reset these freakin valves. The car starts like everything is perfect, I barely touch the starter and fires up and ticks loud.
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Aug 21, 2013
#12
  • Aug 21, 2013
  • #12
If you are using stock length pushrods and didn't check for the correct pushrod length, then you are just guessing. Sorry to tell you but it sounds like you need to check it for the correct length pushrod. You're not going to want to hear this, but it means pulling the intake and at least one set of valve springs off. From the AFR site
Pushrod Length:
This seems like an easily answered question, however there are many variables. Block and cylinder head deck heights, head gasket thickness, varying cams, rocker arms, and valve length can all affect pushrod length. Please see our following best estimates: for 165cc and 185cc standard or .100 long pushrods work in most cases. For 205cc or 225cc typically .100 or .200 long pushrods will achieve proper geometry. For exact pushrod length we suggest using an adjustable pushrod to determine proper length pushrod to be used. For detailed information on pushrod length, please view the FAQ section of our website.
http://www.airflowresearch.com/sbf_faq.php#pushrod
How to adjust stud mount RR and check for proper pushrod length
http://sbftech.com/index.php/topic,317.0.html
Alex sells this nice adjustable pushrod checker
http://www.alexsparts.com/pushrod-length-checker-sbf-302-6-000-7-000-gt40p-gt40-e7/
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,254
204
South Jersey
Aug 22, 2013
#13
  • Aug 22, 2013
  • #13
Is it basically in the middle or actually in the middle? Almost every experience I've had with AFR's have been a little noisy, certainly not like a clock though.
M
mustang 88
60
cleveland ga
Aug 24, 2013
#14
  • Aug 24, 2013
  • #14
Alright this where I'm at now. Order +.100 pushrods and a pushrod lenght tester that I'll use before opening pushrods. But a local motor Guru told me that my lifters need to be upgraded because of the spring load on the AFR's compared to the E 7's. Makes sense to me and I hope it's right because they're 200.00 plus and that's alot when you eyes are half closed. What do you all think about lifter change? Remeber barely off center on valve stem, proper rocker arm adjustment, I start car for a second turn off, and everything is loose again. I know that I have them locked correctly because this is all that I have researched for a week now.Thoughts?
Rick 91GT
Mustang Master
95
99
PA
Aug 24, 2013
#15
  • Aug 24, 2013
  • #15
Im not in agreement with that statement....
Those heads only have 120# on the seat with the stock spring and 135# if you have the PAC upgraded 1.29" diameter spring. That truly is not that much and a stock Ford Racing style lifter is just fine. I've been running those for years with a lot more spring pressure with absolutely no issues....
M6500-r302 $126
It will sound like a sewing machine especially of you have aftermarket valve covers but it shouldn't be ticking like a clock. Did you set the adj guide plates up correct and have good geometry? Do you have adequate clearance on the valve cover or are you possibly hitting them?
On most 302 blocks with a 8.19-8.2 deck height and a stock lifter I am usually at 6.25-6.4 pushrod using a .040" head gasket... but there are a ton of variables and I measure every single one.
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
M
Pushrod length
  • mattcrp1
  • Sep 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 4, 2025
mattcrp1
M
C
347 advice
  • CRonaldo773
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
2000xp8
