push vs pull
  • Thread starter Thread starter railstop
  • Start date Start date May 16, 2004
railstop
311
Colorado
May 16, 2004
  • May 16, 2004
pusher vs puller fan
anyone know what's better for an electric fan, push or pull? and why do you think so. i have heard alot of different opinions, but i just wanted see everyones opionins here.
D
Demented4.6
1,055
DAYTON, OHIO
May 16, 2004
  • May 16, 2004
either is good for the fan but you want to pull cold air through the radiator so you are cooling it instead of blowing hot air from the motor back through
blkstangman88
646
  • May 16, 2004
dastang2
2,020
tx
May 16, 2004
  • May 16, 2004
umm i think the pusher goes in front of the radiator, but i heard the puller was the way to go and if you put both a pusher in front and a puller in back it would cool very well
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
May 16, 2004
  • May 16, 2004
LOL - pushing air back out through the front, huh? bowtiekiller - I think you have the most unique definition of how a "pusher" fan works that I've heard yet.
The puller is definitely more efficient than a pusher - moves more air across the radiator for the same energy input. And a properly sized and designed shroud helps a great deal.
roush 97
86
Illinois
May 16, 2004
  • May 16, 2004
My guess would be best pulling. You put it in front of the radiator it would have to be run more and faster, other wise , if it were off it would block airflow imo.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
May 16, 2004
  • May 16, 2004
It blocks some airflow whether it's in front of or behind - think about it for a second.
railstop
311
Colorado
May 16, 2004
  • May 16, 2004
i can see the the good in both, but one of them has to be a little better.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
May 17, 2004
  • May 17, 2004
From SPAL's FAQ:
Do straight blade fans move more air than curved blade fans?
Yes. Generally straight blade fans will provide greater airflow. Curved blade fans are
designed to be quieter during operation.
If I use your fan, do I need a shroud for my radiator?
In most applications, a shroud is not necessary.
Which fan do I need?
When selecting a fan for your application, choose the fan that provides the greatest
coverage of the radiator core. If space is available, we recommend a pull type fan.
W
2.3l cooling fan questions
  • waxman
  • Jun 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 27, 2026
AeroCoupe
Engine Contour fan CFM
  • Mustang5L5
  • Apr 6, 2026
Fox 5.0 Mustang Tech May 22, 2026
qikgts
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
Forced Induction Total Timing under boost
  • Dontknowchit
  • Aug 27, 2025
Fox 5.0 Mustang Tech Aug 28, 2025
Dontknowchit
Z
Cool fan issues
  • Zipcity
  • Dec 23, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Dec 27, 2025
manicmechanic007
