pushrod length please help
  • Thread starter Thread starter nwander
  • Start date Start date Apr 18, 2005
N
nwander
Ames Iowa
Apr 18, 2005
  • Apr 18, 2005
i am installing edelbrock performer RPM heads on my 68 302. and need to know how long of pushrods to use. i am going to use harland sharp 1.6 roller rockers and a edelbrock performer rpm cam and lifters. not roller lifters but still hydrolic flat tappet. i know i need hardend pushrods for the guidplates but the length is my only question. is the stock length correct or with the 1.6 rockers do they need to be shorter but then i lose what the rockers gain me.
please help
nicholas
68 302 mustang T5 tranny
9in 3.73 posi
17in torque thrust II's
crome yellow
shotsy
233
Oklahoma City
Apr 19, 2005
  • Apr 19, 2005
Stock should work fine unless your heads or block have been milled down? I think I'm right on this but check first with someone who knows for sure so you dont pretzel something!!
jeffnoel
1,638
Clovis, CA
Apr 19, 2005
  • Apr 19, 2005
1.6 is the factory ratio so your not gaining anything from them.
D
D.Hearne
11,730
south louisiana
Apr 19, 2005
  • Apr 19, 2005
please help
nicholas
9in 3.73 posi
crome yellow
The only way to know for sure, is to get a set of "checking" pushrods and use them. Stock length, varies according to year, and valve stem length. Sorry I can't tell you for certain what length you need, but that's what happens when you're trying to assemble a motor with non stock parts. To use the "checking" pushrods, you'll need to wait until the final assembly of the long block, and before bolting the intake on. And preferably with the engine on an engine stand, so you can observe the rocker to valve tip contact without being a contortionist.
jasonn
316
By Rochester MN
Apr 22, 2005
  • Apr 22, 2005
You can do like I did. I just took an old extra stock pushrod, cut a small section out, drilled and tapped the ends that you cut with a 1/4-20 tap. Then take a long 1/4-20 stud and insert it in both ends. Wala, you now have an adjustable pushrod checker.
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
Engine Pushrod Length?
  • foxbodyclark
  • Jan 25, 2025
Fox 5.0 Mustang Tech Jan 25, 2025
limp
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
help me understand calibrated maf sensors and injectors
  • stackz
  • Sep 21, 2024
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 7, 2026
AeroCoupe
