  • 1994 - 1995 Specific Tech
pushrod question....
  • Thread starter Thread starter MI95Cobra
  • Start date Start date Dec 20, 2006
MI95Cobra
451
Oklahoma City
Dec 20, 2006
  • Dec 20, 2006
i'm going to be getting some trick flow heads and using tf stage 1 cam....will i need to get different size pushrods????
jimmy
F
frcefedlx
184
  • Dec 20, 2006
You will need new pushrods, I beleive they are 6.75" or 6.7" inches long however its always best to measure and buy accordingly. When I did the heads on my LX the pushrods in the topend kit were dead nuts on top of the valve so I did not measure them.
RIO5.0
6,892
N.H.
Dec 20, 2006
  • Dec 20, 2006
I believe 6.75 is the stock lenght push rod.
F
frcefedlx
184
  • Dec 20, 2006
Mine are 6.7" and they are hardend for the guide plates.
MI95Cobra
451
Oklahoma City
Dec 21, 2006
  • Dec 21, 2006
these are the heads i'm thinking of.....are they any good...they claim to add 79 hp....
eBay item:Trick Flow 51400004 Cylinder Heads, Twisted Wedge, Ford (#320062802217)
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Dec 21, 2006
  • Dec 21, 2006
Jimmy
I'll not address the length of the pr's
You most likely already know this but, a bit of basic info never hurts
The important thing to remember about TFS heads is ...........
They mandate the use of stud mount rockers
Stud mount rockers mandate the use of pr guide plates
P R guide plates mandate the use of hardened pr's
See how all that kinda goes together hand in hand
To run TFS heads, you can't move over typical oem iron head rockers or pr's from an existing combo.
Grady
MI95Cobra
451
Oklahoma City
Dec 21, 2006
  • Dec 21, 2006
how are the aluminum gt40 x303 heads w/ stage 1 trick flow cam??????
TenorPlayinGuy
1,208
Canyon Country, Ca
Jan 15, 2007
  • Jan 15, 2007
Not to mention that the stock pushrods are only 6.272" long. A good rule of thumb with a set of TF Rockers on TF Heads, I would say a 6.7" pushrod. Its exactly what they install with their kits. However that is with the 1.6ratios.
Rule of thumb for ANY engine build, Get a pushrod length checker with a 8" dial caliper. Measure it and order the closest number
DDSTANG94
465
FRASER, MICHIGAN
Jan 15, 2007
  • Jan 15, 2007
To answer your question of are they good heads the answer is yes. As far as gaing 79 hp it probley wont happen with just the heads alone. IMO get yourself some AFR.
gmkillr
606
Jan 15, 2007
#10
  • Jan 15, 2007
  • #10
99% of the time they will take the 6.700 pushrod, which I just happen to have a set of sitting right here that i'll let go cheap. they are trick flow 6.700 hardned pushrods that are in perfect shape. If your interested pm me or email me at:
rnshuble@yahoo.com
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
T
408w pushrods
  • Towegage
  • Sep 19, 2025
  • Fox Engine Swaparoo
Fox Engine Swaparoo Sep 19, 2025
