put my t5 back together new issues
2fastnotch
61
ok the new problem is the shifter doesnt feel like the detent ball is poping into the holes it also doesnt feel like the shifter goes all the way to the reverse/5th gear part of the pattern does anyone have the instructions from putting the cover back togetherwith shift forks and all
The problem of it feeling like it is not fully engauging each gear could be the shifter stops on the shifter itself. Not sure about stock ones but the aftermarket ones have adjustments on the shifter.. Usually a screw/nut combo for adjusting the stops. If they are set to tightly, that may cause the shifter to not engauge properly.
