qa1 k member a arm install problem
2fastnotch
61
ok i installed my kmemberwhen i went to install the rear A arm bolts there is no enough clearence for the complete bolt head to fit inbetween the rear tab that the arm bolt goes throgh and the tab that bolts the k member to the car. should i clearence the k member or shave part of the bolt head?
im going to run in the same issue because the issue im having is the actual k member. the rear tab for the control arm is connected to the tab for the rear mount of the k member to the chassis it looks like a L bracket theres no room for the head
Picture please! I installed a QA1 K-member, control arms, struts, coil overs, caster/camber plates on my 89 Saleen and had zero fitment issues. Everything went together like clockwork. So i am having trouble "seeing" your problem. Will the bolt go in from the other direction?
You need to grind down the flanges on those bolts. It was in the instructions I received with my QA1 k member. Only two sides need to be ground down.
