QA1 K member
1QWK96GT
44
Helllo everybody. I just recently put in a QA1 tubular k member and it lowered my car another 1" so I brought it back up to a ride height I like. Anyway now everything about my front suspension is screwed. My toe was messed up but I adjusted it. Anyway my caster/camber is all screwed up and I am assuming this can be adjusted with aftermarket caster camber plates. What plates do you recommend. my caster and camber was like 4 degrees off. Also now my tie rod ends and stock control arms on the k member are like a V how do I correct this? its not straight across like with the stock k member. It is V shaped. Thank you.
