Q's about swap
  • Thread starter Thread starter bad95stang
  • Start date Start date Nov 30, 2005
bad95stang
Nebraska
Nov 30, 2005
  • Nov 30, 2005
Hey all, my first post on the StangNet.
I'm want to help a bud (this is his account) swap a late 80s 5.0 into a 1995 v6-t5 stang. I've searched and read some about it, and have gathered that he'll need a new rear axle, but still have some questions. I've done plenty of swaps on GM cars and can fab up stuff if needed, so that won't be an issue.
Sorry in advance, I imagine these are common questions.
Will his v6 t5 bolt up to the v8, or is the bellhousing different. If so, is his stock v6 t5 able to handle a 5.0, or will he need to get it built or get something like TKO t5? I'm pretty familiar with the potential of a bolt-on 5.0, and I'd be doing all of the common boltons (larger TB, cobra intake, etc.) that you 12 seconds foxbodys are doing, so it will have more like 280 hp than the stock 225.
Will he need a new k/cross member for the V8, or will the stocker work. If it will work, will it have provisions to bolt on V8 motor mounts? Kinda the same question in a way, I guess.
I want to keep the EFI on it, what type of computer issues am I looking at? I imagine even if I got a speed-density 5.0 I'd have to swap all of the computer stuff over, correct?
This vehicle is in NE, and we have basically no inspections, so legality of the setup is not an issue (since it's an older motor in a newer car). I imagine there are plenty of aftermarket H or X pipe setups for this 94+ body style, correct?
What about practical weight reduction? Not talking about ricerish stuff like carbon fiber or pulling the interior at the track. But is there more than the AC and smog equipment to save weight? Can I find an aluminum driveshaft for this thing?
And lastly, how much should I expect to find a late 80s/early 90s 5.0 for? I'm talking like an entire setup, I don't want to piece it together.
Sorry again if these are annoying questions. Thanks for any help!
bcd
274
arab al
Nov 30, 2005
  • Nov 30, 2005
sounds to me like you will need an entire wrecked 95 5.0 other wise you are going to have lots of problems. I dont think they put t5s in v6 cars i could be wrong though. Motor wise you will save alot of money if you find an explorer motor with the gt40 heads or gt40 p heads (which need special headers) and change the cam to a HO cam or aftermarket cam. Not sure about the k member but if you have the money and the motor is out you can save about 50-70 lbs on the front end by going to tubular k member and a arms. You will need a v8 computer and motor harness (top and bottom) i think you can leave the suspension and brakes the same but I wouldn't. You can get an aluminum drive shaft from ford racing. do a search on junkyard stuff and you can learn alot. ford put aluminum drive shafts in some minivans that will swap. the explorer intake throttle body and heads are comparable to cobra stuff way better than HO stuff. You may have to change the gauge cluster not sure though i know you do for a four cylinder conversion. changing over all of the accessories from an 87-93 motor to a 95 setup will nickel and dime you to death. but if you can get an explorer motor you will be up on the competition. i think most of this is correct someone will definately let me know if i am wrong. hope it helps
Electrical V8 swap no power to anything
  • Bullittsmith
  • Sep 12, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 15, 2026
Mcmahst
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
D
Yet another v8 swap
  • dulcimerbob
  • Sep 19, 2026
  • 4 5 6
3K
1974 - 1978 Mustang II Talk & Tech Nov 10, 2026
LILCBRA
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
