- Feb 25, 2008
- 8
- 1
- 1
Here is a little background to my problem. I installed a set of new tubular u/l control arms(summit brand) on my car. After the install I ditched the quads, thinking I wouldnt need them anymore. Well the car wheel hopped, so I was told that my shocks could be tweaked, so I went ahead and installed a new set of lakewood 50/50s. Although it helped, wheel hop is still evident so I figured I would put a new set of quads on and finally eliminate the problem.
While trying to install my new quad shocks, I ended up stripping out one of the bolts that fasten the quad shock mount to the frame rail because I didnt have the right hardware. After trying a drill and an easy out I still can not get it out. So I was wondering if I could bolt the quad shock mount down towards the rear of the car, and where the bolt is stripped just weld the mount to the frame rail?????
Also does anybody know what kind of bolts are supposed to fasten down the quad shock mounts because I need to get some new ones. I really need to start labeling this kind of stuff....
Thanks!
Thanks!
