  • SN95 4.6L Mustang Tech
Quad Shocks
  • Thread starter Thread starter DerekStangGT
  • Start date Start date May 4, 2005
D
DerekStangGT
My package is in the mail!
Feb 18, 2003
1,068
May 4, 2005
  • May 4, 2005
do i need em? mods in sig. pretty much every rear suspension part has been upgraded, so do i still need my quads? i just dont want wheel hop since ive heard thats all the quads control is hop. also, can i just unbolt em on rhino ramps? i dont need to lower the axle do i?
dcarlson
128
Long Island, NY
May 4, 2005
  • May 4, 2005
The megabites you have alter the geometry so that engine torque pushes the tires down for more traction. Conventional wisdom says take the quad shocks off so this toque reaction works better.
However, I have found that some cars get a bounce, where the car leaves hard the first 2 feet and then spins slightly a few feet out. The quads will slow the torque reaction and reduce this bounce. Each car is different depending on weight, torque, tires, etc. The ony way to know for sure is try it each way.
They just unbolt. You can do it on ramps if you can get a wrench in there with the tire on.
wms004
2,864
Los Angeles
May 4, 2005
  • May 4, 2005
I have MM LCA's and I removed them. Almost no wheel hop still.
wade
mustang70
2,445
San Diego
May 4, 2005
  • May 4, 2005
You might as well take them off. They could be hurting more then helping. I took mine off and pushed one all the way in with no problem and the other didn't move.
D
DerekStangGT
Feb 18, 2003
1,068
May 4, 2005
  • May 4, 2005
theoretically, i shouldnt have any wheel hop, right? i mean, the whole point of the control arms is to push on the rearend to produce traction. plus the weight of the car shifting back under hard acceleration should limit hop. how do the quads slow the tq reaction? im unsure how they work
dcarlson
128
Long Island, NY
May 4, 2005
  • May 4, 2005
The "bounce" from megabites & southsides isn't the same as conventional wheelhop. It happens when the tires plant so hard the back of the car rises to the end of it's suspension travel, momentarily unloading the tires.
The quads don't directly limit this. Adjustable rear shock valving would do that. But they do soften the axle twisting reaction when the tires load and unload, which leads to wheel hop.
The main benefits to removing them are: 1) increased wheel clearance, 2) a few pounds saved directly over the rear tires (the least beneficial place to remove weight).
Everyone always says "get rid of them." But on a road race course my lap times are better with them.
stangman
2,690
10
69
in a 3 bed, 2 bath
May 4, 2005
  • May 4, 2005
mine have been off for quite a while & never had any problems out of it at all
StangPro
441
Roseville, MI
May 5, 2005
  • May 5, 2005
Take them off.
IF you experience any abnormal bounce throw them back on.
99+% chance you'll be fine though.
Suspension Quad shocks
  • keel
  • May 20, 2026
Fox 5.0 Mustang Tech Sep 2, 2026
AeroCoupe
P
Fox 17" Deep Dish Bullitts on Rear of Fox, 275/40/17?
  • pindude80
  • May 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 4, 2025
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
