Quarter Window Trim....
I think what you have are the covers that go over the old trim.If that is the case they just mount over the old black trim you should not have to remove anything I maybe wrong.
I think it's the actual trim. I bought it from Late Model Restoration. At the very least I will get a pro to take it off and see what I'm left with. If anyone has ever done this let me know.
I considered paint but it is very rough and I wasn't sure if I could sand it or not.
Just bought the trim to replace my old worn out quarter window trim. Does anyone know how to replace that trim? I don't want to start and realize I need a glass installer.
These are molding covers, not replacements. The rubber quarter window molding is part of the window. While they aren't factory, when installed properly, you have to be right up on the car to tell that they are covers.
You are on the right track about taking it by a glass shop. They'll typically charge a few bucks, sometimes nothing, & use windshield urethane to attach them. Best way to install them, by far.
Yea the covers suck. Just recently sold my covers, removed 1/4 windows and restored the trim myself. All you need is some filler primer, 240/320 grit sandpaper, trim paint, and some time. I'm a lot happier now. Here's a link to my write up.
Fox trim restoration - Sandhills Mustang Club Forum
Was there any cracks in your trim? mine has a few, and I was gonna buy those covers, but I guess you'd advise against that.
I mean I'm certainly capable of fixing them cracks and all, I just don't need another time consuming project if there is a simpler way.
Then, by the time I reply, I see the guy above me has answered my concerns
I thought about using those trim pieces in this thread but i saw a picture of them on a car and i really didnt like the look of them. I found a set of notch windows on craigslist for about 50 bucks, and restored those. My original windows molding wasnt worth all the work. Its really not that bad of a job to do them tho, just sand them, then throw some bondo on there, we did two or three coats of etching primer, sanding between each coat and then sprayed them with the same semi gloss that was used on the rest of the trim for the windows
Yea they stick out, spend the time and a few bucks for the supplies and get it done the right way. It wasn't that hard to get to the back of 1/4 windows. Take out all the screws on the rear panels, unbolt seat belts with Torx 50 (top & bottom ), remove speakers, then just work your way around the panel to the 7 or 8 window nuts. Try to do it on a warm day because the old window sealent is pretty tough on a cold day.
Not too many large cracks on mine, just lots of pitting and discoloration. Like 90lxcoupe said try some bondo if you have large cracks.
