Question about Brake Lines
Snikt89GT
264
Deland, Florida
I'm at the point in my 5-lug swap where I need to connect the new brake lines to the factory hard lines and the new calipers. I'm following the M-2300-K instructions but these torque specs on the brake lines can't possibly be right?
How tight should should the brake lines be? I don't know if it makes a difference, but the cobra caliper kit I bought came with goodridge g-stop stainless lines, doesn't have stock lines.
"STEP 30: Install new front brake hoses (Items 16, 17) to calipers with one (1) banjo bolt (Item 18) and two (2) washers (Item 19) per caliper. Torque bolts to 30-40 ft./lbs.
The left front hose (Item 17) will connect directly to the left front brake tube. Torque 124-212 ft./lbs.
For the right front brake hose (Item 16), connect Weatherhead fitting 7828 (Item 48) between the hose and right front brake tube. Torque 124-212 ft./lbs."
Also, does this step really have to be done? Why would you need to move the mounting tab an inch forward?
"STEP 29: You will also have to move the right front brake tube approximately 1" forward. Re-drill the holes for the clip alignment tab (1/4"diameter) and screw (3/16" diameter) using the clip as a template for hole location. Install the mounting clip using the original self-tapping screw. Install front brake hose in the mounting clip."
I think they mean in/lbs...divide by 12 and proceed
as far as the mounting tab, I'm better theres some interference issues they anticipated. I can't really speak for the 2300 kit, since I pieced together my frankenbrakes from a '95 GT and a '90 MKVII.
:mad:
Ok, so who in here has had the banjo bolt shear off inside the caliper when tightening?
:bang:
I was making good progress on the whole swap too..
i remember, the calipers that i bought from advance auto come with a tag that says no more than 15 ft lbs for the caliper banjo bolt. as for the lines, i would tighten them until they wont go anymore / your hands hurt. then drive the car a few times to heat cycle the connections, and retighten them. nearly all of mine were loose after driving a few miles.
yeah, that sounds good. i think i checked mine with a torque wrench once and they were higher than 15...but they didnt leak. check your calipers after every trip for a couple weeks, and see if they leak. if they do, tighten the bolt a little more.
