  • 1994 - 1995 Specific Tech
Question about checking piston to valve clearance
  • Thread starter Thread starter jamnut87
  • Start date Start date Jul 21, 2006
J
jamnut87
46
  • Jul 21, 2006
When you check it is it a good idea to use the new head gasket, or use the old one (if in decent condition)? I have the trickflow H/C/I kit and was wondering before we actually did it, cause i dont want to mess up that Sealing stuff on the new gasket.
thanks
eagleautosports
139
Mebane NC
Jul 21, 2006
  • Jul 21, 2006
You can reuse the old gasket because it's already compressed. No problem with it.
WhiteDevil
2,717
San Diego
Jul 21, 2006
  • Jul 21, 2006
you are using solid lifters right?
J
jamnut87
46
  • Jul 21, 2006
well, since i bought new lifters, were just gonna use an old one and turn it into a solid lifter for checking
thanks for the help
WhiteDevil
2,717
San Diego
Jul 21, 2006
  • Jul 21, 2006
thanks for the help
Yeah i made two of them and then put them in the number one cylinder
Zero Signal
2,633
Tucson, AZ
Jul 21, 2006
  • Jul 21, 2006
I tested with no gasket then with the new gasket to see how close I was to maxing it out. Then I torqued the head and did it again with testing springs (I never used the clay) and made sure it was going to work.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Jul 21, 2006
  • Jul 21, 2006
i did it without and just added in the compressed thickness of the HG to the clay thickness
R
rockin_rick
968
Jul 21, 2006
  • Jul 21, 2006
FWIW - Use clay and not playdoh. Playdoh is too soft and will get into/on top of the valve... I made that mistake. It's also hard to get a good measurement from since it's so gooey.
I got some cheap clay at a local art store.
Rick
J
jamnut87
46
  • Jul 22, 2006
well it shouldnt be too long till we start...
we just finished putting on the new valve springs i bought for the heads (the comp cam 29618 beehive springs), figured i might as well because they will be able to handle it if i wanted to put a different cam in down the road, and they control the valves better in general.... (read an article, and testing showed that compared to a bigger with more weight on the seat (cc987), it bounced at 5650, while the behive with 3 pounds less on the seat bounced at 6650, regardless i know the cars not gonna make power up to 6600rpm with the cam i got) My dad also cleaned up the heads a little bit (there was a little mismatch between the port, and the top of the valve seat (on intake side, wasnt a big deal on exhaust), which was a little obstrution, no major porting or anything) so now everythings nice and smooth
I guess i never really said what i have going into the car
  • Trickflow H/C/I kit (Track heat intake)
  • 255 walbro fuel pump
  • 30lb ford injectors
  • 3/8in intake spacer
  • C&L 76mm Kit (the 76mm meter, inlet tube, and k&n filter)
  • Professional product 70mm throttle body
  • new lifters
And after the motor has a little time to break in
  • King cobra clutch kit
  • UPR adjustable cable/firewall adjuster/ new quadrant
  • new pilot bearing
  • new rear main seal
And then a little after all thats done
H&R super sport springs
upr upper and lower rear control arms
LOTS of work ahead of me and my dad, but its gonna be a great learning experience for me lol
If you guys ever need stuff, go to Artsperformanceparts.com
Art has awesome prices, GREAT customer service.... i bought the actual kit and alot of other stuff from him, he got the bulk of my order (summit covered the rest, accept for the fuel pump)
Thanks for reading...
and thanks for answer the questions about the piston to valve clearance
David
J
jamnut87
46
#10
  • Jul 22, 2006
  • #10
one more question, im looking for a magnetic drain plug, and i cant find the right thing.... Summit says 1/2in 20thread and advance auto parts says 14mm x 1/2in
Anyone like to share what the right thing is
thanks
MysticKeith50
330
Pennsville, New Jersey
Jul 22, 2006
#11
  • Jul 22, 2006
  • #11
I used the used hg, and clay...fwiw, I just did the same thing as you, and trick flow told me not to bother with the piston to valve clearance, since the kit was designed for stock pistons.
R
rockin_rick
968
Jul 22, 2006
#12
  • Jul 22, 2006
  • #12
The beehives are nice. I replaced my AFR springs with those. As you probably already know, they can control better because of the progressive rate and the light weight (small) retainer. I saw a comparison a while back and IIRC, the beehive with a chrome-moly (steel) retainer and steel valve weighs less than a regular spring, CM retainer and titanium valve.
As for the plug - Autozone.com says it's a M14-1.50. I got one at a magnetic one at a parts store (Autozone or Advance Auto or somewhere) and the bolt head uses a 14mm wrench, so that would back up the autozone info as it's metric. (yes, I realize the M14 isn't bolt head size, but my point is that mine is metric, too).
Rick
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
G
4.6L rods and piston into a 5.4L
  • Green mustang
  • Jun 11, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jun 11, 2025
Green mustang
G
