well it shouldnt be too long till we start...
we just finished putting on the new valve springs i bought for the heads (the comp cam 29618 beehive springs), figured i might as well because they will be able to handle it if i wanted to put a different cam in down the road, and they control the valves better in general.... (read an article, and testing showed that compared to a bigger with more weight on the seat (cc987), it bounced at 5650, while the behive with 3 pounds less on the seat bounced at 6650, regardless i know the cars not gonna make power up to 6600rpm with the cam i got) My dad also cleaned up the heads a little bit (there was a little mismatch between the port, and the top of the valve seat (on intake side, wasnt a big deal on exhaust), which was a little obstrution, no major porting or anything) so now everythings nice and smooth
I guess i never really said what i have going into the car
- Trickflow H/C/I kit (Track heat intake)
- 255 walbro fuel pump
- 30lb ford injectors
- 3/8in intake spacer
- C&L 76mm Kit (the 76mm meter, inlet tube, and k&n filter)
- Professional product 70mm throttle body
- new lifters
And after the motor has a little time to break in
- King cobra clutch kit
- UPR adjustable cable/firewall adjuster/ new quadrant
- new pilot bearing
- new rear main seal
And then a little after all thats done
H&R super sport springs
upr upper and lower rear control arms
LOTS of work ahead of me and my dad, but its gonna be a great learning experience for me lol
If you guys ever need stuff, go to Artsperformanceparts.com
Art has awesome prices, GREAT customer service.... i bought the actual kit and alot of other stuff from him, he got the bulk of my order (summit covered the rest, accept for the fuel pump)
Thanks for reading...
and thanks for answer the questions about the piston to valve clearance
David
