I don't know what rear you have, but if that rear was offered with 5 lugs, you could just swap. This assumes that the axle length is the same. You would also need brake drums at the least.
Some rear ends have enough flange to redrill the lugs. This is done to add, subtract, or respace the lugs for different wheel patterns. The drum needs the same treatment.
Good luck
Dave
