Question about dropping fuel tank
UptownGambler1
I am trying to drop the fuel tank out of my 99 GT and need some advice. Does the fill neck have to be removed before lowering the tank? I cannot figure out how the hell it loosens, and 0 out of the ten million parts stores around have a repair manual.
Also, I saw a part of one online that didn't look familiar. It says there are four bolts to undo. I don't have these, or they are in backwards where I cannot get to them under the car. Is this familiar to anyone? Help please...
I had 3 or 4 (forgot) bolts around the gas cap that I had to loosen. Also take off the carpeting in the trunk on the passenger side and there was a rubber boot there you have to take off. After you loosen this rubber/metal boot I bent it in half to get it to drop down through the hole. Let me know if you still need help tommorow (thursday) and I'll check in my car when the sun is up.
Tank
Removal
WARNING: Do not smoke, carry lighted tobacco or an open flame of any type when working on or near any fuel-related components. Highly flammable mixtures are always present and may be ignited, possibly resulting in personal injury.
WARNING: Fuel supply lines on all vehicles equipped with fuel injected engines will remain pressurized for long periods of time after engine shutdown. Fuel system pressure must be relieved prior to fuel system service to prevent possible personal injury or a fire hazard.
Disconnect the battery. For additional information, refer toSection 414-01.
Relieve the fuel system pressure. For additional information, refer to Section 310-00.
Drain the fuel tank. For additional information, refer to Section 310-00.
Raise the vehicle. For additional information, refer to Section 100-02.
Remove the filler pipe bolt attachment and disconnect the filler pipe hose connections to the fuel tank.
Disconnect the fuel tank electrical connector.
Disconnect the vapor tube fitting at the left front of the fuel tank.
Disconnect the EVAP canister tube and hose.
Place a safety support under the fuel tank.
Remove the front two bolts from the fuel tank support straps and swing the LH strap out of the way.
Remove the RH fuel tank support strap bolt and remove the strap.
Partially lower the fuel tank and disconnect the fuel line. For additional information, refer to Section 310-00.
CAUTION: The filler pipe grommet must be removed prior to removing the fuel tank from the filler pipe or damage to the fill tube check valve will occur.
Cut outer edge of pipe-to-tank grommet to facilitate pipe removal and carefully remove the grommet from the fuel tank. Take care to avoid damage to the filler pipe check valve.
Lower and remove the fuel tank.
Installation
CAUTION: Lubricate the filler pipe check valve area and the tank-to-filler pipe grommet with Serfacant (Merpol) ESE-M99B144-B prior to assembly or damage to the filler pipe check valve will occur.
NOTE: A new grommet must be used for the installation procedure due to its destruction during removal.
To install, reverse the removal procedure.
