Question about dual-cat h-pipe
  • Thread starter Thread starter Vatchy
  • Start date Start date Apr 5, 2008
V
Vatchy
10
  • Apr 5, 2008
I bought an almost new Mac dual-cat h-pipe from a guy that used it once on his '87 (or later) Fox. When I found out that it wouldn't fit, I bought a non-cat h-pipe from Summit to replace it. It doesn't fit, either. I called Summit and they said that nobody makes an h-pipe for short-tube headers for an '85.
My question is, what could possibly have changed between the 1985 and 1987 models to make the h-pipe not fit? I have '87-'93 shorty headers on it and they fit perfectly. They're basically the same car with basically the same engine.
I finally just took the car to an exhaust shop and let them build the h-pipe. Not what I wanted, though.
Bullitt347
I have been doing it wrong this whole time
4,061
3,134
204
Middle of Maine
Apr 5, 2008
  • Apr 5, 2008
The trans crossmember the clearance issue? Along with that, the hanger that bolts between the trans crossmember and the trans mount?
V
Vatchy
10
  • Apr 5, 2008
No, the bends in the h-pipe put the exhaust ends too close to the undercarriage.
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Apr 5, 2008
  • Apr 5, 2008
Did you ever see the original headers on the '85?? One of them (passenger side) has a vacuum-operated flapper in it to make the car warm up faster by blocking off exhaust gases. Because of this, the passenger side header flange is larger and located lower. An 86-93 H-pipe will not bolt up to it.
However, if you replace that header with an 86-later header and install a dual-hump crossmember, you are good to go at installing a true-dual system like an 86-later using off the shelf parts.
I beleive te '85 driver's side header is the same as 86-later
86 later headers, h-pipe and cat-back should all fit fine. Where did you have your issue of not fitting
V
Vatchy
10
  • Apr 5, 2008
Yes, I still have them.
I may still have that, although I may have thrown it away, since it came off when I took the headers off.
Yup, did that.
Did that, too.
Nope, that's why I asked the question in the first place. I tried two different h-pipes and they both don't fit in exactly the same way.
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Apr 5, 2008
  • Apr 5, 2008
That's strange. They should have. Where didn't it fit exactly?
J
4 bank eliminator chip
  • JJ's90fox
  • Feb 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 17, 2026
AeroCoupe
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
D
Exhaust Bbk mid pipe and flowmaster catback fitment issues?
  • dqureshi06
  • Jun 8, 2024
Fox 5.0 Mustang Tech Oct 15, 2024
dqureshi06
D
