question about heads
jimc347
77
i have the trick flow track heat package on my car. my friend who builds race engines said trick flow is junk. he said i can get more power out of victor jr heads.???? should i sell my heads and go for something else.?????
Your friend is an idiot and biased against Trick Flow. Go with your own opinions concerning Trick Flow products since you own some of them yourself. Would you buy their stuff again based on your experience?
Also, Victor Jr.s would of course make more power than a 'stock' TW head. An appropriate comparison would be the TFS 'R' vs. Victor JR. Read the MM&FF Ultimate Guide to Cylinder Heads article series on AFR's website... its a lot better source of info than your friend.
Tfs heads are far fom junk. Many many people on here run those heads and with the rest of the street heat kit have been dyno proven to result in 300+rwhp consistently. Although the victor jr heads might make a little more power it will be at a much higher rpm and not very much more than the tfs heads make! If your looking to upgrade heads afr165s are probably the best out there...afr185s if you have a 331 0r 347 :cheers:
Trick Flow makes great products, from what i have heard the Twisted Wedge heads perform a little better than the AFR 165's, the Twisted WEdge head is between AFR 165 and 185. I think Twisted wedge heads are 175's in runner size. You would really get great performance if you ported the TFS heads.
