Question about MSD boxes
  • Thread starter Thread starter 68converted
  • Start date Start date Jan 29, 2006
68converted
772
Colorado
Jan 29, 2006
  • Jan 29, 2006
I want to get an MSD box but which one. I have a modded 5.0 EFI, w/ no supercharger but plan on it down the road. I want to get something that can work with a custom chip, that I plan to get when the SC goes in. I was thinking that all I would need is the MSD-AL. Is that correct?
N8Miller
I need NOS....make it 2 of the big ones
2,661
Kingston, PA, USA
Jan 29, 2006
  • Jan 29, 2006
6a for an auto and 6al for a 5 speed. both will work w/ superchargers and chips.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Jan 29, 2006
  • Jan 29, 2006
Whatchu talkin about willis?
The only difference between the 6a and the 6al is the 6al has the rev limiter. An msd box is a waste of money at your level.
68converted
772
Colorado
Jan 29, 2006
  • Jan 29, 2006
It is an AOD, sorry to leave that info out. So 6A? I just don't want to limit what I need down the road. Is there a better box than MSD for the price.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jan 29, 2006
  • Jan 29, 2006
why not get a digital 6 box it has 2 rev limiters and timing retard capabilities and 2nd rev limiter can be set up for consistant rpm launch at a track.
68converted
772
Colorado
Jan 29, 2006
  • Jan 29, 2006
I am not sure what you mean by my "level"? Can you elaborate?
pb_paulie_b
894
Chaptico, Maryland
Jan 29, 2006
  • Jan 29, 2006
IMHO If you want MSD and there is a supercharger in your plans then get the MSD BTM. It will work without a supercharger and when you get one you will need the timing retard function...PB
Grn92LX
Fidanza Man!
6,819
64
129
New York
Jan 29, 2006
  • Jan 29, 2006
I meant your modification level. You have a n/a 5.0L, an msd would be a waste of money. You will see zero gain. Just trying to save you money. All my friends that I know that have had msd 6al boxes have had it die on them.
68converted
772
Colorado
Jan 29, 2006
  • Jan 29, 2006
Here are my mods: Stock bottom end, XE270HR cam, Edel. RPM2 intake, 24# injectors, 70mm TB, 73 MAF, Non-lockup and very built AOD, MSD coil and Dist. It seems like everyone I have talked to is using the MSD units. Virtually every custom shop builds the ignition around the MSD platform... what's the story there?
Edit- AFR 165's with tripple valve springs, hardened pushrods
pb_paulie_b
894
Chaptico, Maryland
Jan 29, 2006
#10
  • Jan 29, 2006
  • #10
It's really an opinion thing. Things get old and die. MSD boxes are no different. I've had the same 6al box for 6 years now with no problems??? Maybe I'm lucky.
T
TorontoJohn
51
#11
  • Jan 29, 2006
  • #11
I have not shopped for an msd box since I bought mine 3 years ago, but I don't think the 6al is what you are looking for. I think you would want the 6btm. It has a knob for adjusting boost timeing which is good for superchargers.
68converted
772
Colorado
Jan 29, 2006
#12
  • Jan 29, 2006
  • #12
So for cost savings sake, could I just use the 6A box with the boost dial adapter. Should save me about $200 because I can pick up a 6A for about $75 (pulled out of my friends car after two months when he wrecked it). The Boost adapter from Summit runs about $120. Yeah?
pb_paulie_b
894
Chaptico, Maryland
Jan 29, 2006
#13
  • Jan 29, 2006
  • #13
Sounds like my way of think'in. Good plan
N8Miller
2,661
Kingston, PA, USA
Jan 29, 2006
#14
  • Jan 29, 2006
  • #14
ill never admit to being your friend in public, but mine died on me last summer. If it wasnt for a hook up at the local auto parts store, iw ould have had to buy another one, instead, it was exhanged for a new one and labled as defective
HISSIN50
34
129
Jan 29, 2006
#15
  • Jan 29, 2006
  • #15
Though on paper the stock ignition should be good to 350-400 BHP N/A, folks with far less HP have reported things like better idle quality after adding the box.
So while it wasnt necessary, some say it helps. I tore the MSD out of the 94 when I got it just for the sake of doing so, but I wouldnt hesitate to run one (or my preference, Crane) if I had extra money. Given the original poster's current mods and more importantly, future plans, I see no reason not to run a box. Just MHO.
Repostyle
538
Portland, OR
Jan 29, 2006
#16
  • Jan 29, 2006
  • #16
I have a 6a and my mods didn't need it, but I did actually see a gain in fuel mileage. So, if you're planning on getting a SC then I say get it, it will save you some money until then. Probably won't save enough to pay for itself, I noticed only about .5 mpg (hwy), but every little bit helps with todays fuel prices.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Jan 29, 2006
#17
  • Jan 29, 2006
  • #17
My car doesn't have an MSD box, but they are all basically the same. Smoother idle and better gas mileage were my current goals. Later down the road, things might change....
F
86 notch NEED HELP!!!!
  • foxbody86
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
P
Electrical MSD box wiring for an 88 GT- few questions.
  • pindude80
  • Jul 20, 2024
Fox 5.0 Mustang Tech Jul 25, 2024
pindude80
P
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
