Question about MSD boxes
68converted
772
Colorado
I want to get an MSD box but which one. I have a modded 5.0 EFI, w/ no supercharger but plan on it down the road. I want to get something that can work with a custom chip, that I plan to get when the SC goes in. I was thinking that all I would need is the MSD-AL. Is that correct?
N8Miller said:
6a for an auto and 6al for a 5 speed. both will work w/ superchargers and chips.
Whatchu talkin about willis? :p
The only difference between the 6a and the 6al is the 6al has the rev limiter. An msd box is a waste of money at your level.
68converted said:
I am not sure what you mean by my "level"? Can you elaborate?
I meant your modification level. You have a n/a 5.0L, an msd would be a waste of money. You will see zero gain. Just trying to save you money. All my friends that I know that have had msd 6al boxes have had it die on them.
Here are my mods: Stock bottom end, XE270HR cam, Edel. RPM2 intake, 24# injectors, 70mm TB, 73 MAF, Non-lockup and very built AOD, MSD coil and Dist. It seems like everyone I have talked to is using the MSD units. Virtually every custom shop builds the ignition around the MSD platform... what's the story there?
Edit- AFR 165's with tripple valve springs, hardened pushrods
I have not shopped for an msd box since I bought mine 3 years ago, but I don't think the 6al is what you are looking for. I think you would want the 6btm. It has a knob for adjusting boost timeing which is good for superchargers.
So for cost savings sake, could I just use the 6A box with the boost dial adapter. Should save me about $200 because I can pick up a 6A for about $75 (pulled out of my friends car after two months when he wrecked it). The Boost adapter from Summit runs about $120. Yeah?
ill never admit to being your friend in public, but mine died on me last summer. If it wasnt for a hook up at the local auto parts store, iw ould have had to buy another one, instead, it was exhanged for a new one and labled as defective ;)
Though on paper the stock ignition should be good to 350-400 BHP N/A, folks with far less HP have reported things like better idle quality after adding the box.
So while it wasnt necessary, some say it helps. I tore the MSD out of the 94 when I got it just for the sake of doing so, but I wouldnt hesitate to run one (or my preference, Crane) if I had extra money. Given the original poster's current mods and more importantly, future plans, I see no reason not to run a box. Just MHO.
I have a 6a and my mods didn't need it, but I did actually see a gain in fuel mileage. So, if you're planning on getting a SC then I say get it, it will save you some money until then. Probably won't save enough to pay for itself, I noticed only about .5 mpg (hwy), but every little bit helps with todays fuel prices.
