question about rear ends
  • Thread starter Thread starter brtnstrns
  • Start date Start date May 19, 2004
brtnstrns
606
11
Lewisville, TX
May 19, 2004
  • May 19, 2004
i currently have a 200 ci with a 3 spd manual transmission. What i was wondering is if i wanted to swap to a V8 rear end would i also have to switch the driveshaft? Or would a V8 rear end work with the same drive shaft as i have now. I want to get a new rear end so I can have 5 lugs in the back with discs. I already have discs up front and they're capable of being 5 lugs...as long as i put the studs in those holes. Also so when I do a V8 swap in a couple of years i'll alreaedy have the rear end. So will i have to switch anything else besides the rear end if i wanted a v8 rear end?
D
D.Hearne
11,730
south louisiana
May 19, 2004
  • May 19, 2004
As for the driveshaft, maybe. I'd wait and see after installing the rearend.
golf4283
1,253
Orland Park, Illinois
May 19, 2004
  • May 19, 2004
you would need new front spindles to upgrade the front to 5 lug also.
65fastback2+2
1,229
Louisville, KY
May 19, 2004
  • May 19, 2004
sounds to me like he might have 5 lug front spindles???
DukeGnarley
597
Auburn/Ellensburg, Wa
May 20, 2004
  • May 20, 2004
maybe not, he said the rotors could be 4 or 5 lug.
brtnstrns
606
11
Lewisville, TX
May 20, 2004
  • May 20, 2004
the rotors have holes for both 4 lug and 5 lug. It just depends on where you put the studs
allcarfan
The Answer Man
2,458
North Atlanta
May 20, 2004
  • May 20, 2004
you wouldnt need to switch your driveshaft if you changed to a V8 rearend. The only difference in the rearends, to my knowledge, is the axles and the lugs on the end of them.
DukeGnarley
597
May 20, 2004
  • May 20, 2004
you do need to make sure you have the V-8 spindles though, there is a diffrence between the V-8 spindles and the I-6 ones.
killer medic
60
West Palm Beach, FL.
Dec 30, 2005
  • Dec 30, 2005
I am going to see...
I have a 67 pony that was a I6 that was partly converted to a v8. The engine, radiator, shocks, and front springs were changed. I have the rearend from a 67 gt. The front is still four lug, which I will most likely change in the future. I am not racing, draging or anything like that. Just a cruiser and a semi-daily driver. Any tips on the best ways to remove the rearend (by myself, yikes!!!) Thanks guys.:SNSign:
p.s. I still feel like a noob!
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Dec 30, 2005
#10
  • Dec 30, 2005
  • #10
Jack the back of the car, put it on jackstands, and support the center section of the differential with a jack. Disconnect the rubber brake line, E-brake cables, differential vent, and driveshaft. After that, unbolt the back of the leaf springs and disconnect the U-bolts that hold them onto the axle. Lower the rear end and pull it out from under the car.
killer medic
60
Dec 30, 2005
#11
  • Dec 30, 2005
  • #11
thanks buddy
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Dec 31, 2005
#12
  • Dec 31, 2005
  • #12
I've played this game several times.
A 66' 6 cylinder driveshaft will normally be a smaller diameter than a V8 driveshaft. The U joint is also quite a bit smaller and there is no readily available U joint to do a conversion to the larger V8 rear end yoke. So, plan on getting a V8 drive shaft when swapping the rear.
One from a 65'-70' Stang with the similar sized rear will fit. If you install an 8" rear, get one for an 8". If you install a 9", you would want a driveshaft from a 351 or larger car.
killer medic
60
Dec 31, 2005
#13
  • Dec 31, 2005
  • #13
Breaker bar
Invest in a breaker bar if you are going to change your own rearend. BEST TOOL for those stubborn, rusted, siezed, 40 year old U-bolt nuts (or a torch).
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
N
1969 15x10 295's for rear. Modifications needed?
  • normg
  • May 1, 2026
1965 - 1973 Classic Mustangs -General/Talk- May 2, 2026
GypsyR
G
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
