Hi all, I'm looking into building a 64-67 Mustang Coupe. The type of motor I'd like to use is a 347 stroker, mated up to a 6-speed (t-56), aluminum driveshaft going to a 9" rear. I'd also like to run dual electric cooling fans and an aftermarket radiator. I am new to fords and don't really know what goes with what etc. I need to know a few things. Are late model 302 blocks similar to the old blocks? Are there any crossmembers that can be used that retrofit a t-56 into a classic stang? Is it at all possible to use a GM T-56 (they are quite a bit more common) or would a 6-speed from a late model Ford Truck work? Are there any tubular k-members for these body styles and what do they usually run. Which models came with front discs and whats the going rate for a straight body, disc brake, rolling coupe? Also a few websites I've been on says a coupe has a curb weight around 2500-2600 lbs? is this realistic? if its not, what can be done to get them down to around that weight?
