  • SN95 4.6L Mustang Tech
Question about SES Light
  • Thread starter Thread starter mcmmotorsports
  • Start date Start date Jul 23, 2004
mcmmotorsports
689
Danbury, CT
Jul 23, 2004
  • Jul 23, 2004
When I do my Prochamber and O2 Sensor extensions on my '04, I am sure I will get a SES light or maybe I wont. My question is, will the car go into limp mode without the Mil Sims or will it run fine and just have the light on?
mogs01gt
3,113
30
119
Ohio
Jul 23, 2004
  • Jul 23, 2004
it will run fine.
HuskerCobra96
741
Overland Park, KS
Jul 23, 2004
  • Jul 23, 2004
When you remove the cats, you'll get a P0420 and P0430 low cat efficiency codes that will be triggered by your rear o2 sensors. Rear o2 sensors play no role in engine control, so your car will run exactly the same with those codes.
Enter MIL Eliminators. The sole function of MIL Eliminators is to keep your check engine lamp off for the codes P0420 and P0430, but won't alter performance. Think of MIL Eliminators as cheap insurance, as if you don't run them, your check engine or SES lamp will always be on, and if something else goes wrong with the vehicle, and triggers another code, you won't know about it, because your check engine lamp will always be on. Plus, having the check engine lamp on all the time is rather annoying.
To summarize your question, look to the above post. Your car will run the same. If you have any additional questions regarding OBDII diagnostics, feel free to post 'em and I'll make sure you get an answer.
GTvert01
636
West Plains, MO
Jul 23, 2004
  • Jul 23, 2004
Would it not annoy the hell out of you to have that light glaring at you at all times?
mcmmotorsports
689
Danbury, CT
Jul 23, 2004
  • Jul 23, 2004
2 words.....Bulb Removal
Actually, I will spend the money to get the mils but I was just curious cause I won't have them right away.
GTvert01
636
West Plains, MO
Jul 23, 2004
  • Jul 23, 2004
yeah, that will work, but what if you throw a different code?How would you know?Safer to just get the mils. Can't the predator turn off those codes too?
DELOS02GT
461
Naperville, IL
Jul 23, 2004
  • Jul 23, 2004
I turned the rear O2's off and still got an SES light. The code for mine is for the front drivers side O2. I read the stock O2's don't like it when you put on exhaust and they spit out an alarm. I need to replace it with a Bosch O2 and it should take care of the problem. If you get the MIL's and still get the SES light you might have to do this too....
HuskerCobra96
741
Overland Park, KS
Jul 23, 2004
  • Jul 23, 2004
The bottom line is always pull the codes when you get a MIL or SES light. Pinpoint the problem and troubleshoot accordingly.
Here's a quick and dirty FAQ on MIL Eliminator troubleshooting:
http://www.ponyexpressperformance.com/MILtech.html
Keep the rubber side down, fellas.
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
2007 Mustang V6 Auto OD light on and wont go into reverse
  • BlakeusMaximus
  • May 13, 2026
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech May 21, 2026
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
