  • 1994 - 1995 Specific Tech
Question about smog delete
  • Thread starter Thread starter 95Cobra302
  • Start date Start date May 4, 2006
95Cobra302
394
Daytona Beach, FL
May 4, 2006
  • May 4, 2006
Does anybody know what to use to plug the rear of the pass. head when doing the smog delete?? I'm quessing some kind of threaded plug. Does anyone have a pic of what it's looks like and the thread size, and should you apply anything to the threads???
95strokerPSU
986
Sacramento from Philly
May 4, 2006
  • May 4, 2006
I believe its called a thermac plug. Just take the bolts that you removed from the back of the heads and take them to hardware store and get matching thread plugs. I put thread sealant on almost every bolt/plug.
Dan95-5.0
1,110
Manitoba, Canada
May 4, 2006
  • May 4, 2006
i used 9/16 bolts. i used bolts when i deleted my air/egr but for the new heads going on, i got allen screws so it looks a little cleaner
mootang
907
texas
May 4, 2006
  • May 4, 2006
do you have a part # for the allen screws?
95Cobra302
394
Daytona Beach, FL
May 4, 2006
  • May 4, 2006
So how many holes are there going to be 2?? And it's only on the pass. side right?
95strokerPSU
986
May 4, 2006
  • May 4, 2006
From what I remember it's two holes, one on each head. Once you start tearing stuff apart you'll be able to tell for sure...it's a pretty easy job.
slow50sally
66
Hawaii
May 4, 2006
  • May 4, 2006
Two holes back of heads, 1 hole each head. You can see the bolts in the back. There is a metal tube from you smog pump that goes to the back of your pass head which there is a bolt there then the tube connects to the other head. I am in the process of doing mine. I just cut mine by the head and going to plug it. Bolts were rusted.
95Cobra302
394
Daytona Beach, FL
May 4, 2006
  • May 4, 2006
Let me know how it goes. Try to take some pics if you can. Good Luck
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
May 4, 2006
  • May 4, 2006
Yes, there are two holes. One in each head. You will need thermactor plugs. You can buy them at the Ford dealership. They were sold out when I went .... so I ordered two from Summit. I believe they were a TFS part.
Some people have said they used old spark plugs in there. Also, I've heard that you can re-use the tube that you unbolt from the heads by flipping it or something.
SeventyMach1
Mar 30, 2005
1,940
North Carolina
May 4, 2006
#10
  • May 4, 2006
  • #10
This is what you need (unless you decide to do one of the alternate routes).
Part Number at Summit: TFS-51400265 (remember, you'll need TWO)
SVTCobra306
170
Ft. Bragg, NC
May 4, 2006
#11
  • May 4, 2006
  • #11
You can also take the old fitting and flip it backwards so the flat side faces the hole. Just a tad of High temp (red) slicone around the hole will seal everything nicely.
mootang
907
texas
May 5, 2006
#12
  • May 5, 2006
  • #12
thank you seventymach1 that is exactly what I needed.
Smog delete /vacuum lines
  • Serg.Xof
  • Feb 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 18, 2026
RileyDymond
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Gt40 e303 combo questions
  • 99mustanggt2018
  • Mar 30, 2025
1994 - 1995 Specific Tech Mar 30, 2025
KRUISR
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
