Question about subframe connectors.
drivesideways46
26
WV
Hey everyone!
Well, I've decided to go with Maximum motorsports Chassis brace package instead of a new x-pipe. The package comes with full length subframe connectors, K-member brace and a strut tower brace.
My question then is this, is this install too complicated for the local speed shop? I've heard many horror stories about installing subframes on jackstands and all that. Also, will a K-member brace prevent me from installing a new x-pipe?
danny g said:
Whats wrong with installing subframes on jackstands? does the frame sit differently on jackstands than it does on a lift?
Its not an easy install your can read the instructions here. You cannot use jack stands and you need a mig welder.
http://www.maximummotorsports.com/instructions/MMFL-3r2.pdf
it can be done
I installed a Kenny Brown extreme matrix system with jacking rails and subframe connectors while on my back using ramps and jack stands. It can be done, uncomfortable and takes alittle longer, but it can be done. Mig sparks raining down on you also sucks abit.
You have to have the weight of the car on the tires so the springs/body are in normal driving position (loading). I have read threads where the subframes were installed using jackstands or a lift and the doors did not close properly afterwards. Yes, a messed up job, but it can happen. Go to a shop that has done a number of them. You should be OK.
