Question about tach's
  • Thread starter Thread starter brtnstrns
  • Start date Start date Aug 30, 2004
brtnstrns
606
11
Lewisville, TX
Aug 30, 2004
  • Aug 30, 2004
I've got an Autometer Tachometer and was wondering how to hook it up. Its got 4 wires coming out the back...one black, one white, one red, and one green. How do I hook this bad boy up?
O
Ozsum2
695
  • Aug 30, 2004
Most if not all tachs hook up black to ground,white to panel lights, red to hot, and green to the coil.
brtnstrns
606
11
Lewisville, TX
Aug 30, 2004
  • Aug 30, 2004
So could ya'll help me with installation in detail? I'm real good at messing things up so it would be a great help as to where exactly the wires are on the car that would connect to the tach wires
6Stang7
1,470
Livermore, CA
Aug 30, 2004
  • Aug 30, 2004
Connect the black to any ground. The red to a + power source in key ON. The green goes to the negitive since of the ignition coil. The white is for the illumanation light for the tach and you would just splice into the lighting system for the dash.
1969mach1351
285
Sacramento, CA
Aug 30, 2004
  • Aug 30, 2004
Here's a visual.
http://hp.autometer.com/instruction_download/instructions/237j.pdf
F
Fostang
1,400
Stockton, Ca
Aug 30, 2004
  • Aug 30, 2004
Shawn knows.
O
Ozsum2
695
  • Aug 30, 2004
Fostang said:
Shawn knows.
I thought I said that.
F
Fostang
1,400
Stockton, Ca
Aug 30, 2004
  • Aug 30, 2004
Ok Ok you know also.
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
C
Electrical Under dash wiring
  • ChicagoMustang
  • Apr 17, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
Electrical 91 hatch wiring help needed
  • FastDriver
  • Apr 7, 2026
Fox 5.0 Mustang Tech Apr 8, 2026
FastDriver
65 Mustang: Tried to install a tachometer from Oreilly's with no success.
  • spearce
  • Mar 26, 2025
1965 - 1973 Classic Mustangs -General/Talk- May 19, 2026
spearce
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
