Hi everyone. I have a 2001 GT vert with the TR-3650 trans and have the usual problem with the gears grinding on 1-2 and 2-3 shifts when cold. I read through the FAQ about the issue and it was recommended to switch from Mobil1 ATF to Dexron III and lower the level to 3.2 quarts. The local parts places don't carry Dexron III but they had dex/merc which said it was applicable for all older ford transmissions. I spoke to a trans/gear shop and they said they were familiar with the TSB/fix but didn't seem to know about the level adjustment or have a recommendation about the type of fluid. I just replaced all the trans fluid per the owner's manual about 4 months ago (before finding this board) because of the shift problems so I am trying to figure out if I should just drain some of the fluid (Mobil 1 ATF) or should I drain it and replace with the Dexron III (or Dex/Merc).
Also, the trans shop said the parts for the TSB were about $675 and labor $250 for the rebuild if I bring them the tranny and an additional $350 to replace the seals, bearings, etc. Does that sound reasonable or should I try to find the parts somewhere else? Thanks in advance for the help
