Question about turning + acceleration
  • Thread starter Thread starter TyMeFlAmE
  • Start date Start date Jul 30, 2006
T
TyMeFlAmE
  • Jul 30, 2006
If I am turning in either direction and really step on the gas in my 67, I get a lot of noise from, I believe, the back-end of my car. It sounds almost as if something is grinding. Is this common? Is it a sign of an old suspension? Or just something that needs to be tightened? Thank you so much for the help!
Bullitt
Packin' Heat
2,743
Houston, TX
Jul 30, 2006
  • Jul 30, 2006
probably the pinion on the axle winding up and the driveshaft rubbing on the body. this is assuming you've got mostly stock stuff in the rear that's all worn out...
mdjay
Premium Sponsor
Dec 9, 2003
896
Las Vegas, NV
Jul 30, 2006
  • Jul 30, 2006
Could be anything from tire rub, to third member problems?
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
08 Mustang gt high pitched noise from rear
  • sainto
  • Jun 30, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jun 30, 2025
sainto
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
