  • 1994 - 1995 Specific Tech
Question about Upper Intake Bolts
  • Thread starter Thread starter 98Fauxbra
  • Start date Start date Jan 25, 2012
9
98Fauxbra
74
Hotlanta, GA.
Jan 25, 2012
  • Jan 25, 2012
Hey Guys,
I had to pull my upper intake off a few weeks back because the vacuum line underneath it just fell apart. Got everything apart and fixed without worries. When I went to put the upper back on, the outer bolts wouldn't snug down. I pulled them back out, and they look like they may have had some JB weld on the ends at one time. I didn't notice this when I took them out. The gasket is in good shape, the middle bolts were in good shape, and I was in a hurry, so I snugged it down with the two middle bolts. My intake is the Ford Racing version of the 94-95 Cobra Intake. I am wondering if I could get a couple of bolts that are 1/2 inch longer and get into some fresh threads or am I going to have to pull it back off and tap the holes? What I do not want to do is crack the lower. Could I try a little JB Weld? If that is what it is, it held it together without issue for 7 years (I didn't do the intake install, I bought it off the bay and had a shop install it. They are now out of business. Might know why!). It seems to be running fine except that I have developed a strange little hiccup when it is cold (the temp has dropped 'round here lately). I do not know if this is related to the loose outer bolts or not. I cleaned the MAF last night, it was pretty filthy, and that seemed to help some this morning. I checked the grounds on the engine while I was under it last weekend, they were fine, and I am going to check the ground for the Computer tonight when I get home. Any thoughts would be appreciated. Thanks.
Bryan
Admin Dude
Jan 4, 1985
43,353
21,554
234
Box behind Walmart
Jan 25, 2012
  • Jan 25, 2012
Drill em out and install heli-coils
Sent from my HTC Aria
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Jan 25, 2012
  • Jan 25, 2012
I agree with the helicoil method. You can do that with the lower still on the car. Just stuff some rags in the ports to keep the metal shavings out.
Kurt
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Jan 25, 2012
  • Jan 25, 2012
If they are stripped I wouldn't put anything like JB Weld, Epoxy, etc in those holes. I agree, Helicoil them and they'll be good as new. Aluminum parts are tricky especially intakes. They require very light torque 12-18lbs. Any more than that and it's stripped.
9
98Fauxbra
74
Hotlanta, GA.
Jan 25, 2012
  • Jan 25, 2012
Thanks guys. Kinda what I was thinking. I hadn't planned on the JB unless everyone on here had the exact same problem and it worked wonders. Any idea if I might have a little more vacant space in there for a slightly longer bolt? I ordered the correct 94/95 Cobra Bolt kit from Ford 7 years ago when I had this done. It only came with two bolts for the middle becuase they were supposedly longer than the original ones. Thanks for all the help
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
Someone help me understand this, Intake opening to throttle body opening
  • from6to8
  • Jul 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2025
from6to8
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
