  • 1994 - 1995 Specific Tech
Question and a pic......
  • Thread starter Thread starter BlueOvalStangGT
  • Start date Start date May 9, 2004
BlueOvalStangGT
2,849
Tampa Florida....USF!!!
May 9, 2004
  • May 9, 2004
Heres the fitting for my F/P guage and i think that that is the shrader valve in the back. Am I correct? The guage fitting is too big, should I just go buy an adapter?
BlueOvalStangGT
2,849
May 9, 2004
  • May 9, 2004
forgot the pic......
BlueOvalStangGT
2,849
May 10, 2004
  • May 10, 2004
cmon people,
GTPhreak
5,505
Rowlett, TEXAS
May 10, 2004
  • May 10, 2004
pic is hard to see. is that a mechanical fp gauge? if so what size is the line? go buy a -3 or -4 AN fitting depending no what size the hose is. you need a 1/16 npt > -3AN fitting i would imagine
S/CBlack95GT
2,018
Tampa Palms, FL
May 10, 2004
  • May 10, 2004
That line you are holding looks like a compression fitting, which will not mount to a schrader valve.
BlueOvalStangGT
2,849
May 10, 2004
  • May 10, 2004
that line is connected to the sender for the electric fuel pressure guage,where does it connect?
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Idler pulley as substitute for Power Steering Pump ?
  • Bhenders
  • Jul 15, 2026
  • Other Auto Tech
Other Auto Tech Jul 16, 2026
LILCBRA
