Hey, when you put you're rear Baer kit together, did the instructions for any reason tell you to remove the axle bearings from the axles themselves. I'm asking because I'm rebuilding my rearend and I have the old bearing pressed off the axles and I'm ready to press the new ones back on. But because I haven't received my Baer kit yet I don't know if it's okay. I don't want to find out after I've pressed on the new bearings that the Baer kit requires me to add a bracket in between the the bearing and the stud flange that would need to be slid on the axle shaft before the bearing is pressed on.
I did talk to a rep at Baer with this question and he said that their bracket sandwiches with the factory end plate and that it doesn't require me to mess with the bearing.
But I thought I'd ask someone who's been there just as backup...
Thanks for your time.
