question for jrichker
jammer84_03
468
ok, power window question. do you have a schematic for the power windows. i had my driver side window just completely stop working, it wasnt slow or anything before it happened, although i just did a tint job and the door panel apart. i might have possibly jolted a wire loose and it took a mth for the wire to come out somewhere. i havent taken it apart to check it yet, but is there and easy way to test my window motor, switch, and the wiring to track down my problem before i start going and ordering parts? thx for the help - james
When you hit the switch for the window, does the voltmeter drop any? Probably not. Check the switch connector in the door panel.
Good luck.
ya...tonight once i get out of work i will test all the theories out. i knew this prob would arise sooner or later...this is the week of nickel dime stuff, the pass side door lock froze in the unlocked position, the driver side window wont open, and on the way to work this morning, the complete pass rear brake assembly came apart. got out to look at it and there were no brake pads!...lol and those were tightened to spec. also i think my axle bearings are going out. when i take off from a stop and sometime when i shift into the next gear from a roll i hear a popping noise from the rear end, might be the u-joints or bushings...not sure til i look.
