  • SN95 4.6L Mustang Tech
Question for those with 4.10's
  • Thread starter Thread starter flstang65
  • Start date Start date Dec 20, 2008
flstang65
1,484
135
94
SE Georgia
Dec 20, 2008
  • Dec 20, 2008
For those of you that have 4.10's, what rpm's are you turning when you are running 70 mph and then 75 mph? I was driving to work the other day and there was a sign showing everyone's speed. Either they upped the speeds to scare people to slow down, or my car is still off. I got the complete built rear end (with less than 5000 miles on it) out of my friends Saleen that he totaled, and he was insistent that they were 4.10's. I have corrected the computer with my tuner. I'll post the rpms for my speeds later after I can get it on the highway again, I am having one huge brain fart right now. The rear end is an 8.8, 31 spline axles, Auburn posi. and I run either my stock 245/45 17's or 275/45 17 drag radials.
BTW, I only paid 200 for the whole thing! Then I sold off my stock rear for 350.
joshjwc9
1,095
17
39
Palm Harbor, FL
Dec 20, 2008
  • Dec 20, 2008
Sounds like you have either 3.55 or 3.73, but if I were you I would jack up the car and check the driveshaft revolutions...
flstang65
1,484
135
94
SE Georgia
Dec 20, 2008
  • Dec 20, 2008
i checked it before i installed it while i had the whole rear end out of the car. my friend and i checked it countless times and both came up with around 4 revolutions of the yoke per one revolution of the axle. maybe im just losing my mind???
flstang65
1,484
135
94
SE Georgia
Dec 20, 2008
  • Dec 20, 2008
Well, after doing some HW and using the ever so valuable search feature here on stangnet, I have come to the conclusion that I do, in fact have 4.10's I called the guy I bought the rear from to confirm and hes going to fax me a copy of the receipt just for my piece of mind. Lol. Thanks for looking anyways guys.
trinity_gt
3,125
81
99
Canada
Dec 20, 2008
  • Dec 20, 2008
The difference between 3.7 turns and 4.1 turns may not be easy to distinguish. If you can, try turning the wheel ten times and look for ~35, ~37 or 41 turns of the driveshaft.
Or you could remove the rear cover and count gear teeth to know exactly what you've got.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Dec 20, 2008
  • Dec 20, 2008
I have a 96 Cobra with 4.10's T45, 23 tooth white speedo gear with 275-40R17's and my speedo is right on. I just put a new gear on the tail shaft of the transmission too, so I know it's perfect. At 80MPH I am at 2,900, so 70-75, it's prolly 2,600-2,700.
I know it used to be off because after I smoked two speedo gears, it dished the drive gear on the tail shaft and at 90MPH it was reading 3K, so I knew it was 10 fast. I just had all that fixed in November.
Tim2002GT
635
Tulsa, Oklahoma
Dec 20, 2008
  • Dec 20, 2008
With 275/40/17's, at 70 mph I am turning a hair under 2400 rpm. I have 4.10's also.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Dec 20, 2008
  • Dec 20, 2008
At 70 I am at 2600...245/45/17's up front.
ErikTheBeast
124
Kansas City MO
Dec 20, 2008
  • Dec 20, 2008
With my 285/35/18's and my 4.10's I'm @ 2500 doing 70 ( I have a 4r70w btw )
BurningRubber
1,865
24
58
Dec 20, 2008
#10
  • Dec 20, 2008
  • #10
This is with a T-45 transmission, RPM's will be slightly less with a T-3650 as 5th gear is a little deeper...
315/35/17 tires out back, speedo corrected with a Diablosport Predator.
YouTube - 4.10's 60-80mph, RPM check.
Tim2002GT
635
Tulsa, Oklahoma
Dec 22, 2008
#11
  • Dec 22, 2008
  • #11
Guess I should add that I also have a 3650.
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
