Question for Thumper
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Ok if you can answer this question you will have yourself a customer! Can I use your heads in my 88GT with Typhoon upper and lower, LT's and an Hpipe, stock fuel system from pump to injectors and stock cam and rockers with an SD set up, and have no tuning to do? I want a rebuild with with some power 260-270RWHP but not have to fuss with the set up like most due when they run H/C/I combo's. I have spent the better part of 1-1/2 years bringing this car back from the dead, and to be honest I just want a good strong reliable 5.0 with nice solid idle and fun on street drivability. Anyone else with simular set up please do give up advice.
When flow increases, you need either mass air or a custom chip. If your running the typhoon intake now, you probably are having a/f ratio issues now. Most likely your idle would suffer as well.
I don't see how idle could suffer since all factors at idle would remain fairly close to stock..I have the typhoon on now with the exhaust and pullies with no idle issues at this time...
