  • 1994 - 1995 Specific Tech
QUESTION NEED AWNSER ASAP. (how much to chop off springs for 1/2" drop)
  • Thread starter Thread starter 91LX_5L
  • Start date Start date May 27, 2005
91LX_5L
1,943
41
British Columbia
www.voltagenewmedia.com
May 27, 2005
  • May 27, 2005
How much should I chop off my eibach pro springs for about a 1/2" drop. 3/4 coil?
E
EpiKk3
405
  • May 27, 2005
Can't answer the question sorry to get your hopes up.. but why in the world are you cutting eibachs?
91LX_5L
1,943
41
British Columbia
May 27, 2005
  • May 27, 2005
Because they sit dead even, front looks higher then the rear. I was thinking of more like 1/2 coil which is pretty much the dead coil anyways.
RIO5.0
6,892
N.H.
May 27, 2005
  • May 27, 2005
I cut my Macs...1/2 coil was 1/2" drop for the front.....1 full coil was worth 1" in the rear....
Hopefully you got decent struts/shocks as the rides gonna firm up and spanked out S/S are gonna show up with a chittier ride....you 'll notice a dif in the handling to....
Dont forgot to compensate for the rear drop by adjusting the pinion snubber accordingly....otherwise she'll be hitting hard from bottoming out on the snubber...you may need to cut a 1/2" of rubber off to start ??...I would assume you have a shorter snubber from when the Eibach's went in??
E
EpiKk3
405
  • May 27, 2005
Good enough reason .. Mine sits the same unfortunately
91LX_5L
1,943
41
British Columbia
May 27, 2005
  • May 27, 2005
Ok 1/2 coil it is thanks!
94-302-vert
1,947
NE CT
May 27, 2005
  • May 27, 2005
I would do a half max then try it, then go for more if needed.
Or even get height measurements, cut a 1/4" then reinstall and measure.. Then see where that leaves you and if you want lower.
Remember you can't go back after cutting your springs.
Chris
D
66 Coupe Progress Thread
  • DTCRAWLEY
  • Apr 19, 2026
  • 2 3
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
DTCRAWLEY
D
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
