  • 1994 - 1995 Specific Tech
Question on 99-up calipers
  • Thread starter Thread starter Killercanary
  • Start date Start date Jan 27, 2004
  • 3
First Prev 2 of 3 Next Last
Last5.0
404
Jan 29, 2004
#21
  • Jan 29, 2004
  • #21
Anyone know if 15" Prostars will clear these calipers??
P
pbr brakes
#22
  • Feb 3, 2004
  • #22
Killercanary said:
I think I remember reading on here that the 99-newer front calipers are made of aluminum and are lighter than our stockers, can anyone confirm this? Has anyone done this swap? If so, what all is needed? I'm looking for ways to lose weight and upgrade at the same time. Any info is appreciated.
I work at a PBR Brake Manufacturer. I make Mustang Brakes calipers all day every day. We are a tier one supplier to Ford. All the calipers we make are aluminum. They are melted, poured in dies, milled with a CNC machine & assembled. When they arrive at Ford facility from our plant they merely place them on the rotor & connect the brake line.
We discard thousands on a daily basis. I can buy all I want at a deal.
We also make all calipers for the Cobra, Corvette, Cadillac, all Chevy SUV's, some Toyotas and some general GMC vehicles...like the Aztek, Hummer and so on...
BlueOvalStangGT
2,849
Tampa Florida....USF!!!
Feb 3, 2004
#23
  • Feb 3, 2004
  • #23
hey ill take a pair, if you can
P
pbr brakes
#24
  • Feb 3, 2004
  • #24
i am new at this....still learning how to send messages and find 'threads'.. i think that is what they are called...anyway you are in florida.....i am not sure what shipping costs
....i can get you a set
BlueOvalStangGT
2,849
Feb 3, 2004
#25
  • Feb 3, 2004
  • #25
send me an email with some prices, BlueOvalStangGT@aol.com
GTPhreak
5,505
Rowlett, TEXAS
Feb 3, 2004
#26
  • Feb 3, 2004
  • #26
What is the reason they are discarded? What kind of pricing can you get on them?
blksn955.o
3,263
st.louis mo 314
Feb 3, 2004
#27
  • Feb 3, 2004
  • #27
I read in a mag somewere that the 99+gt pbr twins pistons are bigger than the earlier cobra twins, not by much but bigger is bigger, Also A bud a few months ago upgraded his 00GT to a baer kit and his new calipers were preaty close to the stock one, the rotor was bigger and cross drilled and slotted, as well as coming with ss braded line. We did this at about the time 5.0 or MM&FF did the brake pad test and from looking at the two pbr calipers one diff. would be the hawks pads with the baer kit. Using good pads seems to be one of keys to get the 99+ calipers to realy show how good they are.
GTPhreak
5,505
Rowlett, TEXAS
Feb 3, 2004
#28
  • Feb 3, 2004
  • #28
94-98 cobras had 38mm twin piston calipers, and the 99+ used 40mm twin pistons. I believe those figures are accurate. 99+ gt/v6 had 44mm twin piston calipers. the reason the cobras can get away with the smaller pistons is because they have more leverage from the larger rotors
Killercanary
The car that set the bar.
Altoona, PA
Feb 3, 2004
#29
  • Feb 3, 2004
  • #29
Man your a day too late... I bought a set yesterday at a junk yard. MANY 94-98 owners do this swap as we get twin piston calipers and lose 16lbs in the process. Depending on good of a deal you can offer them at, i may buy another set since they are "new" instead of unknown junk yard stuff.
SmokinGT50
733
Atlanta, GA
Apr 8, 2004
#30
  • Apr 8, 2004
  • #30
I am in the process of adapting the front C5 brakes to my 95 GT. When everything is combined together, the caliper, the brackets, and the rotor; the C5 brakes are 1.5lbs lighter each side then the stock GT setup. Also the stock GT caliper weighs 9lbs. each, not the 15-20 I've read about. So unless the 99+ calipers only weigh 1 lb. you are not going to lose 16 lbs. in this swap.
Killercanary
Altoona, PA
Apr 10, 2004
#31
  • Apr 10, 2004
  • #31
Steve, you are right. I weighed them today, the PBR's fully dressed with the bracket and pads weighed in at 10lbs, the stock with pads and such weighed in at 13lbs, so the total loss is only 5-6lbs. I was a little disappointed, but they look good and should help me stop better none-the-less.
331 cobra
398
Silicon Valley CA
Apr 10, 2004
#32
  • Apr 10, 2004
  • #32
Can you get the Baer PBR's? I think Roush has Cobra style PBR's too.
It would be cool to get the expensive brand PBR's cheap.
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Apr 11, 2004
#33
  • Apr 11, 2004
  • #33
HEY STEVE!!!-nice seeing you back on here!
Paul, They DID help me, but I guess I was expecting WAY Better stopping, because after we put them on my car, I was like "not too bad".. I was really excited.
None-the-less, they cost me $100 for both fronts, and I even got the rotors with it. Car they came from had 5k miles on them. My stock rotors were 10 years old and pads had about 10k miles.
All in all, not a bad mod if you get a good price. I still like those cobra 13" ones tho.
RC
Slow5.0
2,554
Portland, OR
Oct 18, 2004
#34
  • Oct 18, 2004
  • #34
Sorry to bring old thread
I have realy bad brakes for some strange reason so I decide to go on junk yard and get some 99+ GT/V6 front brakes
I wanna know what I have to get from junk yard
AND
What I have to do that swap
I know I need calipers,rotors and what else ?????????
Killercanary
Altoona, PA
Oct 18, 2004
#35
  • Oct 18, 2004
  • #35
brackets and banjo bolts. You can upgrade to SS lines too if you want, I was being cheap and just used the stockers. You will have to grind down the caliper a little where the brake line attaches if you use the stockers, and a very small amount will need to be removed from the spindle, but we're talking less than 1/16".
94GTLaserRC
11,178
Oct 18, 2004
#36
  • Oct 18, 2004
  • #36
Werd!
A Dremmel with a medium grinding wheel is enough to do the trick. I even talked to a couple of guys that said they didnt even have to grind at all!
RC
94TURBO5 O
2,509
VA
Oct 18, 2004
#37
  • Oct 18, 2004
  • #37
On my Cobra brake kit it's a 99+ and it was direct fit on everything.
Ernie
I have my stock calipers, brakets, hoses with carbon metallic pads (80% left) and zinc plated cd/slotted rotors in my garage. You can have them for $200 + the actual shipping charge.
(I'll be @ Mason Dixon racing on the 23rd if that's close for you to p/u.)
Slow5.0
2,554
Portland, OR
Oct 18, 2004
#38
  • Oct 18, 2004
  • #38
What brackets and banjo bolts
Do you have any pics how that grind job looks like
Killercanary
Altoona, PA
Oct 18, 2004
#39
  • Oct 18, 2004
  • #39
Caliper brackets from the 99-up car, and the banjo bolts from the 99-up stock brake lines. My salvage yard just cut the lines right off the car and left the banjo bolt connected to it and the caliper. Get yourself some new copper washers though too for the banjo bolts.
GTJake
3,049
Ann Arbor, MI
Oct 18, 2004
#40
  • Oct 18, 2004
  • #40
Paul- Did you measure a difference in weight between the two.
Jake
  • 3
F
Difference between 83-86 EFI and 87-97 gas tanks?
  • ForeverDrivin
  • Mar 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 30, 2026
ForeverDrivin
F
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
ATS brake conversion question
  • stackz
  • May 16, 2024
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 25, 2024
Mustang5L5
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 23, 2026
JH96GT
