  • SN95 4.6L Mustang Tech
Question on Engine
  • Thread starter Thread starter WPBFL561
  • Start date Start date May 24, 2010
W
WPBFL561
  • May 24, 2010
Hey guys, I recently took my engine to a machine shop for a diagnose. I have engine knock. They called me telling me before they start this that the average engine rebuild for this engine 4.6l from mustang bullitt gt. is $2400. I explained I did not want a rebuild and just wanted to fix the rod knock but they said you can't just open the engine and put the old stuff back in. Is this correct? I dont rly need a rebuild as it only has 65000 miles on it. for $2400 cant I go ahead and buy a new engine? Please send advice, thanks.
Corey
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
May 24, 2010
  • May 24, 2010
Yes for $2100 to $2400 you can get a re-man SOHC GT engine. But after the machine shop goes over your motor, it will be for all intensive purposes a zero mile re-man unit. I presume it will have a warranty as well.
The machine shop is in a tough spot. To diagnose the problem much disassembly is required. The labor involved to test every part to see if it is re-useable is much greater than the cost of the parts.
How would you feel if the motor was put back together with used parts and a problem quickly occurred?
If 2400 is too steep for you, try the salvage yard approach. For sample prices, go to car-part.com. It is a searchable web site of linked salvage yards.
I recently purchased a 30k mile engine from a 2004 Crown Vic for 800. The motor is in my 2000 Mustang GT and is running great!
If you really want to perform a min re-build, you may have to do some of the disassembly yourself. Have the machine shop work on just the pieces that you want. They will charge based upon what you want done.
If $$ are an issue but you don't want to do the engine disassembly/reassembly yourself, it is hard to argue with the salvage yard route.
W
WPBFL561
  • May 25, 2010
Hey Burns thanks for the reply! Not sure if it is warranteed, it's weird because I haven't signed anything or seen any papers. think its "underground" work. I think it might just be one or two bent rods that why I don't want to go ahead with a full rebuild.
I asked if they could just diagnose it for me and then ill pick the parts up and rebuild it myself. There's no reason why I can't use all the old parts except for what is broken, but they seem to tell me I cant use all the old parts. only 65k miles.
I was thinking of just getting a cobra or stage 2 SOHC crate engine, do you know a website that I can get one of these?
And then just parting out my current engine.
I could go ahead and do the rebuild myself thats what my friend is telling me to do and he said he will help. Is there any good books on my engine to do this?
Thanks,
Corey
T
tikibeast
59
Victorville, Ca
May 1, 2011
  • May 1, 2011
Amazon.com: How to Rebuild 4.6-/5.4-Liter Ford Engines (S-a Design, Workbench Series) (Cartech) (9781932494808): George Reid: Books
I've seen this book recommended a few times.
robo
132
cleveland ohio
May 1, 2011
  • May 1, 2011
2400 is dirt cheap for a quality machine shop to rebuild an engine.
Maxpowers
859
Pittsburgh, Pa
May 1, 2011
  • May 1, 2011
I would rather buy a used motor before I spent that much.
robo
132
cleveland ohio
May 1, 2011
  • May 1, 2011
and you will get what you pay for!
never enough money to do it right the first time but plenty of money to do it over and over again.
JymboSlice
385
May 2, 2011
  • May 2, 2011
trinity_gt
3,125
81
99
Canada
May 2, 2011
  • May 2, 2011
Corey
The problem is that a knock implies a bad bearing. Suppose it's a big-end on a rod: From there you may go to metal-on-metal contact with a journal on the crank probably causing dings and grooves; the bearing shell may have spun in the connecting rod ruining it and of course when a bearing lets go, it literally lets go of a bunch of loose metal that can circulate through the oil to other parts and damage them.
You actually can open and engine and, if everything checks out (no cracks, nothing worn beyond spec etc), you can break the cylinder glaze with a hone, put fresh rings and bearings in it and be good to go. However, if the knock has caused problems like those mentioned above, you're going to be in for replacement parts, machining etc.
It might be worth pulling the pan off it and checking to see what you're up against before committing either way. Find the loose rod and remove its cap. Check the bearing condition...did it spin? Any metal transfer to the journal? etc. Mic the bore and the journal. Check the journal for grooves and metal-transfer etc etc. Only after a check like this can you judge whether just the source of the knock can be addressed (still leaves metal in the oil galleries...) or whether it has to come right down for a rebuild. Don't expect any machine shop to offer any sort of warranty on a mere bearing shell replacement to cure a rod knock...
What caused the (presumably, rod) knock?
Rick 91GT
Mustang Master
95
99
PA
May 3, 2011
#10
  • May 3, 2011
  • #10
Trinity is 100% correct....
What I do with custohimers is first pull the pan and check the bearings and look everything over. Depending on what I find I layout the options on repair.
Most of the bolts are tq to yeild and will need replacing, if the crank has any marks it will need a polish or turning.
Rods, pistons and.crank can be reused of everything else checks out...it is 100% determined on what is found. What are your future plans with the car? The stock internals are weak....
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
9
WTB: Procharger or Vortech Supercharger – 1996–1998 Mustang GT 4.6 2V – Budget $3,200
  • 96mustang.gt
  • Nov 20, 2025
  • Want to Buy
Want to Buy May 3, 2026
roblabsn95
R
