Question: On flywheel bolts, do I use BLUE loc-tite or RED loc-tite?
Chythar
Recently finished repairing my rear
Aug 26, 2004
2,373
140
113
Foothill Ranch, CA
I've been told use RED loc-tite on the driveshaft bolts, but I have to heat the bolts up to remove them. Should I just use blue loc-tite on the flywheel bolts?
Thanks.
loc tite
When I changed my fox body to a 5 speed I used the red loctite and had no problems. You know someone will say it. Did you read the package. DUH
It may help. I got a long screw driver put it in the flywheel teeth and used a large breaker bar to get the flywheel bolts off. A 400ft lb impact wrench would not break them lose.
What package to read? I know that red loc-tite is high-strength and blue is not. But the flywheel bolts may not need the stronger red loc-tite. The OEM bolts I removed did NOT have loc-tite on them, just that red rubber-like stuff. I've seen the same stuff on my ECT and CTS, used for a fluid-proof seal. No remnants of loc-tite at all.
Use whatever makes you happy...they both do the job well
Me personally I always use red loctite on my car as well as customers' cars. I have never had a problem breaking them loose with the trusty impact ;) .... it laughs at red loctite lol
In the end, I decided to use blue loctite. There is a flywheel-specific loctite available, it has the same properties as the blue loctite, including its melting point (300F). Only difference is that the green was designed to cure in a tightly-sealed area. Many crankshafts have holes for the flywheel that do not go all the way through. Blue loctite would not dry well in those cases. However, the 5.0 crankshaft hoes go all the way through so the blue should cure just fine.
Thanks for the advice, everyone.
I don't understand why anyone would want to chance it with anything else. I don't know about you, but I don't like to drop my tranny every week. I use red on everything, always have. And you had to put heat on the d/s bolts? I just use the 2 wrench trick for leverage and it works everytime. But it does take some elbow grease to get those off, and that's a good thing!
Flywheel bolts = red loctite.
But, blue loctite is still loctite so you'll be fine.
That is correct, Loctite is an anaerobic sealer, meaning it doesn't need oxygen to harden. The green loctite is meant to penetrate screws/bolts that are already in place
btw, I mainly use red loctite because I have a huge bottle of it that needs to be used lol
The OEM bolts had the rubber seal because the holes go all the way through to be exposed to the oil pan and all the oil. On the old (Like 60's&70's) cranks the holes didn't go all the way through so they recommend Loctite. On the new 5.0 cranks the manual says to use a thread sealer Not Loctite so it won't leak oil through the holes.
I just did an Escort and it was the same thing, the red rubber stuff stock and it said to use a thread sealer with Teflon on the bolts in a manual.
I can tell you this about crankshaft/flywheel bolts :)
Back in the 60's and 70's we did not use Loctite on ANYTHING :eek:
and
We never had anything fall off :rlaugh:
I know the bolts these days go all the way through and oil can
seep past the threads :(
I see the concern of more importance to be to seal the threads
as opposed to keeping the bolt secure ;)
I could say the same about drive shaft bolts
We never used Loctite on em and none of em came loose :shrug:
I mean ... you had fine threads and lock washers :)
Most likely ... Ford started the Loctite application to save the
cost of 4 lock washers :Word:
Grady
Locktite??? I don't use that stuff at all....Matter of fact i use antiseize on driveshaft bolts for YEARS. Maybe i should change the way i do things??? Then again like Grady said i think my driveshaft bolts are 12 point and have lock washers.
The DS bolts come from Ford with threadlock instead of washers.
I like Grady's reasoning. Chemical washers are cheaper than metal ones.
I have had driveshaft washers back out on me before.
Kurt
