  • 1994 - 1995 Specific Tech
Question on O-ringed heads
  • Thread starter Thread starter 94blackGTvert
  • Start date Start date Oct 7, 2004
9
94blackGTvert
63
PA
Oct 7, 2004
  • Oct 7, 2004
Ok, I'm finally going to get around to doing h/c/i in a month or so. I'm gonna go with the trick flow package and get O-ringed heads.
So my question is, do you have to/is it necessary/or even possible to also O-ring the block??
I'm still undecided as to whether or not I'm going to do a supercharger or turbo set up, but I'm not going to be running a whole lot of boost. All I'm looking to get is 400-450 rwhp and an 11 second time slip when it's all said an done.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Oct 7, 2004
  • Oct 7, 2004
I have read here that the o-ringed heads are complete crap. They say that it's just better to use studs in stead of bolts for the heads. Again that's just what I have read on here on Stangnet.
9
94blackGTvert
63
PA
Oct 8, 2004
  • Oct 8, 2004
what makes them crap? do they not seal as well? the price difference in heads for non 0 and 0-ringed is only 60 bucks, are they not worth it?
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Oct 8, 2004
  • Oct 8, 2004
The Fel-Pro o-ringed gaskets are also more expensive. I bought a pair or used GT-40 irons that had been o-ringed; the gaskets themselves are $60 EACH. I got a pair on eBay for $80, so saved me some cash.
moneypit94
1,723
Macomb, IL
Oct 8, 2004
  • Oct 8, 2004
I found out through personal experience that if your going to have a power adder o-ringing your heads is THE way to go. I blew my first headgasket a shortwhile after i had my blower on. They were felpro's. Then after that i tryed copper headgaskets.. I had absolutly no luck with them. I called trick flow and they told me to have the heads o-ringed and use the loc-wire gaskets..
I haven't had a problem sence and its been like 5-6 months and i drive my car every day. Not to mention i have a slight lean condition at higher rpms and i have made 12 lbs of boost on my 9.7:1 motor.
Far as having your block o-ringed too.. I would. Im going to on my next setup coming up here shortly.
Like trick flow said, once you do that you don't have to worry about your headgaskets again. But if its not tuned correctly that may mean damaging other stuff.
And when Jesse had his turbo setup and blew the headgasket on the dyno (AF was good), I would put dollars to donoughts (as my old 1SG use to say) that if he would have had them o-ringed that he wouldn't have had any problems.
M
2001 evap/heater core questions
  • mnky99
  • Sep 3, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 3, 2025
mnky99
M
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Fuel Pump O ring
  • TIGGER
  • Oct 21, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 15, 2024
manicmechanic007
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
