question on tranny install
  • Thread starter Thread starter 1991vert
  • Start date Start date Oct 30, 2005
1991vert
1,103
Ludlow, MA
Oct 30, 2005
  • Oct 30, 2005
when i did my tranny a few years ago i noticed that my shifter didn't sit "centered" in the shifter hole. i had a busted motor mount and thought that was the reason. well i did a tko swap on my friend's car and his is the same thing. both are off to the right. when it's in first it looks like it's in 3rd, maybe even 5th to some. the way the crossmember attached looked fine. do we have it reversed on both cars? should we flip it around and wedge it into place with a crowbar and bolt it down? i dont want to end up putting any unneccessary force on the bolts and having them snap or something worse.
any opinions?
is the off centered part normal?
1991vert
1,103
Ludlow, MA
Oct 30, 2005
  • Oct 30, 2005
ttt no one?
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Oct 30, 2005
  • Oct 30, 2005
bad motor mounts are usually the cause. Might want to check the motor mounts and trans mount and replace.
If you change the motor mounts, remember to loosen the trans mount and center it before the final tightening of the motor mounts.
1991vert
1,103
Ludlow, MA
Oct 30, 2005
  • Oct 30, 2005
both mounts are new. so i take it this isn't a common occurance?
Grn92LX
Fidanza Man!
6,819
64
129
New York
Oct 30, 2005
  • Oct 30, 2005
What trans? My tremec doesn't sit centered either and its normal.
1991vert
1,103
Ludlow, MA
Oct 30, 2005
  • Oct 30, 2005
it's the newer t-5 that says "Tremec" on it
1991vert
1,103
Ludlow, MA
Nov 1, 2005
  • Nov 1, 2005
ttt
Euphoric306
905
  • Nov 1, 2005
woot just put in my tranny i didnt check to see if it was centered in the cutout hole but it shouldnt matter
found out ive got energy suspension tranny mount
1990LXDropTop
430
Western Massachusetts
Nov 2, 2005
  • Nov 2, 2005
Chris-
My shifter is now level as I switched the shifter handle over to the left side. I found out that the handle is suppose to be bolted to the LEFT side of the shifter stub and not the right. All is well now and I'm sure yours will be too once you swap the handle to the left side. Try it and see...
1991vert
1,103
Ludlow, MA
Nov 2, 2005
#10
  • Nov 2, 2005
  • #10
mien's on the left. maybe it's my tranny mount or something
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
Sound deadener install
  • limp
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 17, 2026
limp
