Question. Shocks and Gears
BGBDDAD
17
Huntsville, AL
I just found out I have a left rear leaky shock. My car is still under warranty so I am taking it to the dealer on Monday. Will the dealer have any performance shocks I can pay a little extra for? Also, I am going to get some FRPP 3:73 gears put on sometime. I am thinking while I have it at the dealer they can do it (if they have them in stock) and flash the speedomoter. Right? :shrug:
They will probably be considerably more expensive on the gear change than an outside shop. The left rear shock on mine leaked as well, maybe it's a disease among '03 models.
2001 Geee T said:
Thats funny because my left rear shock is leaking too!
Are shocks coverd under warranty? Im sure mine arent anymore thanks to the springs.
I just spoke with the dealer and the shocks are covered. They have the 3.73 gears for around $200, but he said the labor would be about $400 and then they can't even flash the speedometer. You would have to find someone with an aftermarket Tuner.
You can use a "SpeedCal" which cost $80 or so instead of a flash tuner to correct the speedometer. If you have the money however I would recommend the tuner.
