questions about wheels......
etid
New Jersey
I don't want to do a 5 lug conversion, so no Prostars for me. Here is the second best option:
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM-521-5834PS&N=700+0&autoview=sku
Would it be dumb to run 15x8s all the way around? I don't really like the skinny look in the front.. What is the widest Nitto I can fit on an 8 inch rim.. 275?
Also, how much would 18in. cobra r's weigh down the car? Enough to make it run like **** at the track? I admit, I am a track junkie.. I can't decide which i want to go with.. drag look or street look..
All comments and/or criticism welcome..
:SNSign:
795.0pacecar
lover of pudgy polygamists
Jul 11, 2003
480
Senoia, GA
You dont have to put skinnies on the front, but they can be smaller than the rears. Have a 6 or 7" wheel with 205s or 215s on the front and an 8" wheel with 275s on the back or something along those lines.
etid
New Jersey
They are my number one choice.. 18x9 all the way around. 255 in the front, 275 in the back. Then lowered 1-1 1/2 inches with wither B springs or Eibach, haven't deicded. Then to top it off I am going to get the Lakewood shocks and struts.. It should handle like it is on rails and ride smooth as stock. :nice:
Is cutting springs a SERIOUS disadvantage when it comes to ride quality? I've seen cut B springs, 1 coil cut all the way around and it looked sharp, not to mention they are a load cheaper than Eibachs.. opinions? I don't know jack about suspension. What is my best bet for good launches at the track?
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
If you want to spend more time at the track, what you plan to do is a bad way to make it work. 18s on a lowered suspension is NOT going to hook and get you good times. You dont need skinnies, but a 15" wheel with some sidewall, and some narrower (likw 205-215s) front tires would be a good bet!
etid
New Jersey
What about 17s with a wide nitto and stock height, upper and lowers and new shocks and struts?
Also, do 17x9's rub the front, I have heard they do and don't..:shrug:
SPEEDYLIFSAVR
666
FL,89 LX 5.0
I have 17x9's and took them off because of rubbing issues . But my car is an 89 with the smaller wheel wells/fenders . I believe 90 and up have the wider fenders and rubbing should not be an issue . I am selling my 17x9's .
jfran430
36
Connecticut
Well i have a 90 gt and i am running 17x9's now ... but i only have 235/45 tires on there ... they lookterrible so i want to upgrade to 255/40 .. anyone dones this?? and does anyone have any rubbing issues??
